1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: USB-scopes, anyone?
Date: Fri, 4 Feb 2011 13:36:50 +0100
First, thanks to all who replied. We are also persuing network connected
scopes, but when I wrote the original message I was not aware of any, thus
my question for USB scopes.
We evaluated the ZTec a while ago and found it usuitable for our demands
(mostly regarding stability/usability).
Our standard (and fallback) solution is to use Tektronix scopes, controlled
over vxi-11/asyn/streamDevice. This is very easy to set up and program. It
just seemed a waste to mount a regular scope with front panel and display in
a rack and hide it behind a door.
Cheers
Ben
On Friday, February 04, 2011, Bruce Hill wrote:
> We've had some success with ZTec scopes.  They run EPICS
> on the boxes, allowing you to run a linux flash utility to update the
> startup file which sets the PV names, and they provide a minimal EDM gui.
> We didn't have to use any windows software to configure them.
> For us, they serve a niche that needs digitized signals captured in
> EPICS with
> more flexible triggering and sampling options than our dedicated
> digitizers, but where the setup doesn't change often.   The gui is
> adequate for
> this use, but while you could use it with a laptop for portable
> diagnostics, a small test scope is much more user friendly.
> Regards,
> - Bruce
> On 02/03/2011 04:32 AM, Benjamin Franksen wrote:
> > We are interested in evaluating USB-scopes (rack-mounted, no front
> > panel) for continuous signal measurements, as these are a lot cheaper
> > than regular scopes (with display and front panel controls). However,
> > it is unclear whether remote access to such scopes necessarily means
> > using proprietary (vendor supplied) software under Windows. Ideally,
> > we would like to have an asyn driver for USB (or some more specific
> > protocol over USB), and then use stream device support on top of that.
> > Failing that, we would have to explore other possibilities, like
> > running an IOC on a Windows machine with a special device support that
> > talks with some (proprietary) vendor library.
> > Has anyone already done something like that? If yes, which
> > manufacturers/devices are you using? Has anyone experience with
> > programming USB? Could the protocol be reverse engineered?
> > Cheers
> > Ben
> > ________________________________
> > Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> > Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> > Forschungszentren e.V
> > Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
> > stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph Geschäftsführer: Prof.
> > Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt,
> > Dr. Ulrich Breuer
> > Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> > Postadresse:
> > Hahn-Meitner-Platz 1
> > D-14109 Berlin
> > http://www.helmholtz-berlin.de
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn- Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
D-14109 Berlin
USB-scopes, anyone? Benjamin Franksen
Re: USB-scopes, anyone? Bruce Hill
Prev: Re: Trouble with mcaR6-12-4 and EPICS 3.14.12 (cygwin-x86) Carl Willis
Next: FYI - CVS access issues at Sourceforge Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: USB-scopes, anyone? Bruce Hill
Next: EPICS Codeathon 2011 Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
