I probably have a little different take than Jeff.
While giving the user of 'epicsEventWait()' a 'bad' error status back
offers the opportunity to react to an error
it also burdens the user because he/she then has to check a return
code to make sure that a seemingly trivial operation suceeds.
E.g., when I take a mutex I don't always want to have to check
a return code. Often, I consider the case of failure when taking a mutex
a fatal error. Either due to a programming error (e.g. an invalid
mutex ID) or lack of system resources. Either way, I consider
the possibility of failure with a need for graceful recovery
marginal and the added effort to implement such a recovery
too expensive. However, I also don't want to just take the mutex
w/o making sure I really own it because that would leave
a critical section exposed. Therefore, I really love
epicsMutexMustLock() (even though it's implementation using 'assert'
is flawed since 'assert' becomes a no-op if you compile with the
symbol NDEBUG defined -- assert should IMHO replaced by cantProceed).
Long story short - I'd suggest to provide two interfaces
epicsEventWait() and epicsEventMustWait().
Regarding the posix implementation I consider the operations of
taking/releasing the mutex associated with the condition variable
of the class 'mustSucceed' since this mutex is entirely 'owned'
by the implementation. If epicsEventWait() returns anything
this should be the return value of 'pthread_cond_wait()'.
-- Till
On 02/01/2011 01:54 PM, Andrew Johnson wrote:
The current Posix implementation of the epicsEvent API contains many uses of
its local checkStatusQuit() macro to detect and handle situations where the
OS' pthread routine returns an error — it prints an error message, then calls
cantProceed() which halts the thread. In some cases the API leaves little
choice on what /can/ be done, for example the epicsEventSignal() routine
returns void, so there is no way to signal a fault up to the caller.
In other cases though we can return an error, and I'm working on changing some
of the internals to just print a warning message and do that instead. For
example, epicsEventCreate() is allowed to return NULL; epicsEventMustCreate()
is provided for users who don't want to handle failures themselves.
That leaves a few additional cases: epicsEventDestroy() warns but continues if
either of the pthread_xxx_destroy() routines complain, which seems sensible
(it may leak memory, but we have reported something).
The interesting question (the main purpose of this message) is what to do if
pthread_mutex_unlock() returns an error at the end of the epicsEventWait()
routines. Currently the code uses checkStatusQuit() so will halt the thread,
unlike the other implementations.
A discussion on what the epicsEvent routines should do on getting an error
from the OS routines is welcome (but Argonne is about to shut down for a 12"+
snow-storm so don't expect an immediate response from me).
- Andrew
- RE: epicsEvent (posix implementation) bug ? Jeff Hill
- epicsEvent (posix implementation) bug ? Till Straumann
- Re: epicsEvent (posix implementation) bug ? Eric Norum
- Re: epicsEvent (posix implementation) bug ? Andrew Johnson
time discontinuity detected Carsten Winkler (HZB)
<2011>
<2011>
