make -np | grep INSTALL_BIN
# makefile (from `/usr/local/epics/base/3.14.11/configure/CONFIG_COMMON', line 93)
INSTALL_BIN = $(INSTALL_LOCATION_BIN)/$(T_A)
Got it! Thanks,
E
On 13:59 Tue 01 Feb , Andrew Johnson wrote:
> Hi Emmanuel,
> On Tuesday 01 February 2011 11:54:09 [email protected] wrote:
> > I have been crosscompiling for arms on intel cpu some time now.
> > Each time I cross compile, only the host binaries are installed.
> > what about the target binaries/libraries?
> How have you configured your build to cause the host binaries to get
> installed? Please be explicit, listing the names of the files you've changed
> and the settings you've made in those files.
> It should be possible to do what you want if you configure it right.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
Emmanuel
- crosscompilation and installation of bin/lib emmanuel_mayssat
- Re: crosscompilation and installation of bin/lib Andrew Johnson
Re: crosscompilation and installation of bin/lib emmanuel_mayssat
RE: epicsEvent (posix implementation) bug ? Jeff Hill
<2011>
time discontinuity detected Carsten Winkler (HZB)
<2011>
