Hi EPICS community,
Has anybody tested the ip330ScanMode template to change the scan mode of a ip330? If so, could you share your substitutions file to create records
using the ip330ScanMode.template? I've tested the ip330ScanMode template with the following substitutions file and it doesn't appear to work. When I run my system without this scanmode template, and initialize the ip330 for scan mode 3, the ip330 runs fine
in the continuous mode. When I include the scan mode template, and set the scan mode to 3, the ip330 data only updates one time. I’m using ip330-2-6 with epics base 3-14-11.
# file ip330ScanMode.template
file "$(IP330)/ip330ScanMode.template"
pattern
{P, R, SCANMODE, PORT}
# SCANMODE = 3 for continuous, 4 for triggered
{21:D3:, ADC, 3, "b-ADC}
Jay Steele
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error,
please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
- Re: ip330ScanMode template question Andrew Johnson
Re: epicsEvent (posix implementation) bug ? Andrew Johnson
<2011>
Motor driver for Parker Hannifin ACR series controllers? Mark Rivers
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
