1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsEvent (posix implementation) bug ?
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Mon, 31 Jan 2011 09:28:50 -0800
This topic seems to have shifted a little.
It started out as discussing the semantics of epicsMessageQueue with multiple readers.  The shift to the semantics of epicsEvent with multiple waiters is a result of the POSIX implementation of epicsMessageQueue.
I think that both issues are worthy of discussion and that there's likely more than one place in the appDevGuide that could use such a statement.
FWIW, both vxWorks and RTEMS currently provide FIFO semantics for both epicsMessageQueue with multiple readers and epicsEvent with multiple waiters.....
On Jan 31, 2011, at 9:09 AM, Jeff Hill wrote:
Ø  Not sure about windows, but since priority inversion is a major issue only for
Ø  systems with strict priority-based scheduling I'm not sure that it's that big a
Ø  deal there anyhow.
So I can confirm that Windows does not support such options, and agree that this is probably because it isn’t that type of (strict priority scheduled) OS. I am going to guess that Windows CE also doesn’t allow for such options.
Perhaps the application developers guide should say something like this.
“Where possible and reasonably efficient the OS specific implementation of the event semaphore should select options which provide priority based queuing, but portable source codes who are consumers of the epicsEvent interface should not depend of this feature nor allow its absence to substantially change their run-time behavior.”
Eric Norum
[email protected]
Re: epicsEvent (posix implementation) bug ? Till Straumann
RE: epicsEvent (posix implementation) bug ? james.rowland
Re: epicsEvent (posix implementation) bug ? Eric Norum
RE: epicsEvent (posix implementation) bug ? Jeff Hill
Prev: RE: epicsEvent (posix implementation) bug ? Jeff Hill
Next: Re: epicsEvent (posix implementation) bug ? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
