1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: ca_create_subscription element count
To: <[email protected]>, <[email protected]>
Date: Mon, 31 Jan 2011 09:13:58 -0700
> If the count in ca_create_subscription is > 1 and the type is
> DBR_TIME_STRING, is the event_handler_args.dbr->value set to an array of
> strings?
Yes, an array of dbr_string_t - each element is a fixed length buffer of
size dbr_string_t, but a variable length nill terminated string is stored
therein.
> Also, when I try to do a ca_create_subscription on the excas pv named
> albert (1000 elements), I get from the SEVCHK:
> CA.Client.Exception...............................................
>     Warning: "The requested data transfer is greater than available
> memory
> or EPICS_CA_MAX_ARRAY_BYTES"
>     Context: "ca_create_subscription"
>     Source File: ../ca_monitor.cpp line 163
>     Current Time: Fri Jan 28 2011 13:23:19.178091145
> However, if I run the included camonitor tool on albert, it works fine.
> Would this be because I am requesting the subscription with the
> DBR_TIME_STRING?
Yes, string arrays use quite a bit of space compared to doubles. In R3.14
you can set EPICS_CA_MAX_ARRAY_BYTES in the environment of both the client
and the IOC to extend the limit.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of [email protected]
> Sent: Friday, January 28, 2011 2:31 PM
> To: [email protected]
> Subject: ca_create_subscription element count
> Hi,
> strings?
> memory
> DBR_TIME_STRING?
> Thank you again for your time,
> Patrick
ca_create_subscription element count pthomas
Prev: Re: epicsEvent (posix implementation) bug ? Eric Norum
Next: Re: epicsEvent (posix implementation) bug ? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: ca_create_subscription element count pthomas
Next: epicsEvent (posix implementation) bug ? Till Straumann
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
