1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca_create_channel memory management
To: [email protected]
Cc: [email protected]
Date: Fri, 28 Jan 2011 17:53:00 -0600 (CST)
No.  In the best case, you call ca_clear_channel() and then
free pUserPrivate.
Probably Jeff Hill can just tell us if it's possible for a sent
monitor (or other callback) to arrive after ca_clear_channel() has
been called.
You could test to see if it's possible, by modifying your
cleanup routine to change *pUserPrivate after calling
ca_clear_channel(), instead of freeing the pointer.  Then cause
value changes to the monitored PV at a high rate (preferably the
PV is in a different IOC), and call cleanup().  If your callback
routine ever sees the value of *pUserPrivate that you wrote in
cleanup(), you know it's possible.  You might have to do this many
many times, though, before you hit the time window in which a problem
occurs. It's worth the effort, though, because problems like this that
are hard to reproduce are many times more frustrating in a deployed
system than they are in a development system.
Tim
----- Original Message -----
To: "Tim Mooney" <[email protected]>
Sent: Friday, January 28, 2011 5:09:44 PM
So in the best case scenario, I could just call ca_clear_channel after I
free pUserPrivate? Is there a way to determine if the worst case scenario
exists? If it does, is there anyway to fix or avoid it?
> Yes.  I'm worried about monitor (and other) callbacks that are
> in transit while the channel is being cleared.
> However, in the cases in which I needed to worry about this there was
> a software layer between the decision to clear the channel and the
> actual call to ca_clear_channel().  It may be that channel access
> somehow claws back sent monitors when a channel is cleared, but that
> has never been my understanding of how it works.  If it does work that
> way, all that I would worry about is that you're freeing pUserPrivate
> before calling ca_clear_channel(), thus opening a tiny time window in
> which a race condition is possible.
> Tim
> From: [email protected]
> Sent: Friday, January 28, 2011 3:04:41 PM
> Do you mean calls to the monitor callback function that have occurred
> prior to calling ca_clear_channel, but that somehow have not been
> processed?
>> I thought that ca_clear_channel took care of that? From the ca reference
>> manual:
>> Clearing a channel does not cause its disconnect handler to be called,
>> but
>> clearing a channel does shutdown and reclaim any channel state change
>> event subscriptions (monitors) registered with the channel.
>> Thank you,
>> Patrick
>>> If your channel is doing any callbacks (e.g., you're monitoring it),
>>> you might have outstanding monitors at the time you decide to clear
>>> the channel.  You need to tell your callback routine to ignore any
>>> calls that come after you've called cleanup(), so it doesn't reference
>>> pUserPrivate after it's been freed.
>>> Tim
>>>> To: "Andrew Johnson" <[email protected]>
>>>> Sent: Friday, January 28, 2011 11:56:37 AM
>>>> So:
>>>> void cleanup(chid ChanID) {
>>>> void* pUserPrivate;
>>>> pUserPrivate = ca_puser(ChanID);
>>>> free(pUserPrivate);
>>>> ca_clear_channel(ChanID);
>>>> > Hi Patrick,
>>>> > On Friday 28 January 2011 11:10:29 [email protected]
>>>> > wrote:
>>>> >> If you allocate memory and send a pointer to it in the puser field
>>>> >> of
>>>> >> ca_create_channel, does it get freed when ca_clear_channel is
>>>> >> called, or
>>>> >> should I do that explicitly?
>>>> > There's no way the CA API could know whether it should do that or
>>>> > not, so
>>>> > it
>>>> > doesn't and it falls on you to do it yourself.
>>>> > - Andrew
>>>> > If a man is offered a fact which goes against his instincts, he will
>>>> > scrutinize it closely, and unless the evidence is overwhelming, he
>>>> > will
>>>> > refuse to believe it. If, on the other hand, he is offered something
>>>> > which affords a reason for acting in accordance to his instincts, he
>>>> > will accept it even on the slightest evidence. -- Bertrand Russell
>>> Tim Mooney ([email protected]) (630)252-5417
>>> Software Services Group (www.aps.anl.gov)
>>> Advanced Photon Source, Argonne National Lab
Re: ca_create_channel memory management pthomas
Prev: Re: ca_create_channel memory management Matthieu Bec
Next: Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Setting BPTR Till Straumann
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
