1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Setting BPTR
To: [email protected]
Date: Fri, 28 Jan 2011 16:33:19 -0600
Hi Till,
On Friday 28 January 2011 15:04:10 Till Straumann wrote:
> I see that the problem for aao/aai was fixed in
> 3.14.12 but it would be nice to be able to set
> BPTR for waveforms, too.
I don't see any obvious backwards-compatible way to allow that.
I just compared the (3.14.12) aai and waveform records, and I don't really see
much difference between them, other than allowing device support to set BPTR
and the BUSY field (which I don't think anyone uses any more); couldn't you
just convert your waveform device supports to aai/aao instead?
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Setting BPTR Till Straumann
Prev: Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
Next: Re: ca_create_channel memory management pthomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Setting BPTR Till Straumann
Next: ca_create_subscription element count pthomas
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
