1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ca_create_channel memory management
To: "Andrew Johnson" <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 28 Jan 2011 10:20:26 -0800 (PST)
I'm not sure what you mean by "never set puser to anything else other than
zero."?
> On Friday 28 January 2011 11:56:37 [email protected] wrote:
>> So:
>> void cleanup(chid ChanID) {
>>     void* pUserPrivate;
>>     pUserPrivate = ca_puser(ChanID);
>>     free(pUserPrivate);
>>     ca_clear_channel(ChanID);
> Looks reasonable, assuming you used the {m|c|re}alloc() routine to get the
> pointer in the first place and you never set puser to anything else other
> than
> zero.
> BTW on Windows you have to call free() from the same DLL as the *alloc()
> call.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Re: ca_create_channel memory management Andrew Johnson
ca_create_channel memory management pthomas
Re: ca_create_channel memory management pthomas
Prev: Re: ca_create_channel memory management Andrew Johnson
Next: Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: ca_create_channel memory management Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
