So:
void cleanup(chid ChanID) {
void* pUserPrivate;
pUserPrivate = ca_puser(ChanID);
free(pUserPrivate);
ca_clear_channel(ChanID);
> Hi Patrick,
> On Friday 28 January 2011 11:10:29 [email protected] wrote:
>> If you allocate memory and send a pointer to it in the puser field of
>> ca_create_channel, does it get freed when ca_clear_channel is called, or
>> should I do that explicitly?
> There's no way the CA API could know whether it should do that or not, so
> it
> doesn't and it falls on you to do it yourself.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
- Re: ca_create_channel memory management Andrew Johnson
- Re: ca_create_channel memory management Tim Mooney
- ca_create_channel memory management pthomas
RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
<2011>
<2011>
