Hi Patrick,
On Friday 28 January 2011 11:10:29 [email protected] wrote:
> If you allocate memory and send a pointer to it in the puser field of
> ca_create_channel, does it get freed when ca_clear_channel is called, or
> should I do that explicitly?
There's no way the CA API could know whether it should do that or not, so it
doesn't and it falls on you to do it yourself.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: ca_create_channel memory management pthomas
- ca_create_channel memory management pthomas
Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
<2011>
<2011>
