Hi EPICS community,
I’m running EPICS 3.14.11 on Windows XP and using windows extensions 32 MEDM as the GUI. I’m trying to run bash scripts from MEDM. I’m able to launch a xterm from a button created using MEDM’s shell command palette. The xterm window
runs cygwin and I’m trying to use an argument to xterm to run the bash script. My problem is that the command line arguments are not parsed correctly when I specify two command-line arguments for xterm. I can run the following from a windows DOS window: xterm
–e “dxpflyscan.sh /cygdrive/c/epics/bash/mca1.txt”. This works to create the cygwin xterm window and launches the dxpflyscan.sh script with /cygdrive/c/epics/bash/mca1.txt as an argument. However, the following does not work with MEDM. I just get a flash of
a DOS window.
“shell command” {
object {
x=70
y=167
width=127
height=42
command[0]{
label=”dxp-flyscan”
name=”xterm”
args=”-e “dxpflyscan.sh /cygdrive/c/epics/bash/mca1.txt””
Has anybody had better success at getting bash scripts to work with MEDM on windows/cygwin? MEDM does work when I only specify the shell script name as an argument to xterm.
Cheers,
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error,
please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
- Re: problem running bash script with MEDM on Windows/Cygwin Tim Mooney
- Re: problem running bash script with MEDM on Windows/Cygwin Andrew Johnson
Re: Py-Epics and string waveform records Matt Newville
registrySetTableSize() unusable Till Straumann
<2011>
Re: OMS VS4 "omsPut: card 0 send ring full!" Nerses Gevorgyan
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
