1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Py-Epics and string waveform records
To: [email protected]
Cc: [email protected]
Date: Thu, 27 Jan 2011 16:38:30 -0600
Hi Craig,
I think I have string waveforms working, but I haven't done a lot of
testing with this code (especially for what I may have broken in the
process).    If your interested in trying this out and verifying that
this works for you, you can checkout the 'stringarray' branch from
github:
    git clone http://[email protected]/newville/pyepics.git
    git fetch origin stringarray:stringarray
    git checkout stringarray
I'll try to get this better unit-tested and released in a few days,
but I'm trying to get ready for experiments next week too, and am
reluctant to break too many things right now.
Cheers,
--Matt
On Wed, Jan 26, 2011 at 11:08 PM, Matt Newville
<[email protected]> wrote:
> Hi Craig,
> Sorry for the trouble.
> I've never tried a waveform of strings -- I didn't know it was
> possible, actually.  I can see that a) it is possible, and b) that the
> current pyepics code makes the assumption that a DBR_STRING PV cannot
> take more than 40 characters total, regardless of element_count.
> That's probably why you're seeing only the first element of the
> waveform.
> I see a possible fix, and will try to test it tomorrow.
> Cheers,
> --Matt Newville <newville at cars.uchicago.edu> 630-252-0431
> On Wed, Jan 26, 2011 at 9:50 PM,  <[email protected]> wrote:
>> Hi,
>> Does anyone know if Py-Epics should be able to correctly read/write string waveform records?  I only seem to be able to access  the first element.
>> using caget (C utility) from base is OK, it returns all elements
>>>caget  stringWaveform
>> has09eenv:weather:area1:test 5 testing one two three four
>> but using Py-Epics I only see the first although the count is correct
>> In [12]: pv=epics.PV('stringWaveform')
>> In [13]: pv.get()
>> Out[13]: 'testing'
>> In [14]: pv.count
>> Out[14]: 5
>> float waveform records are fine though.
>> Thanks
>> Craig Haskins
>> Software Engineer
>> Australia Telescope National Facility
>> CSIRO Astronomy and Space Science
>> P.O.Box 76, Epping NSW 1710, Australia
>> Phone: +61 2 9372 4309
>> email: [email protected]
Py-Epics and string waveform records Craig.Haskins
Re: Py-Epics and string waveform records Matt Newville
Prev: Re: bo Record not forcing VAL to 0 or 1 Bruce Hill
Next: problem running bash script with MEDM on Windows/Cygwin Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Py-Epics and string waveform records Matt Newville
Next: OMS VS4 "omsPut: card 0 send ring full!" Nerses Gevorgyan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
