1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: GigE driver for Area Detector
To: <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 26 Jan 2011 20:45:27 +0000
Mark is right. We pass the .cmd file through MSI to generate the boot
file. The rule is:
%.boot: ../%.cmd
        $(MSI) $(SYS_BOOT_FLAGS) $(USR_BOOT_FLAGS) $< > $@
This is so we can have identical startup scripts for different
architectures.
However, in this one off case, it should be easy enough to edit the .cmd
file and manually substitute the macros.
Cheers
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Rivers
> Sent: 26 January 2011 19:35
> To: Szalata, Zenon M.; Cobb, Tom (DLSLtd,RAL,DIA); tech-
> [email protected]
> I think they generate their startup files from a script.  You probably
> need to manually create an st.cmd file based on their template.
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Wednesday, January 26, 2011 1:33 PM
> To: [email protected]; [email protected]
> Hi Tom,
> I downloaded the tar file from the link below.
> I am having trouble building the examples.  I get this error:
> make[4]: Entering directory
`/afs/slac.stanford.edu/g/testfac/vol4/workspace/zms/rhel5/R3.14.11/ioc
aravisnew/aravisGigE-0-1-2/iocs/example/iocBoot/iocexample/O.linux-x86'
> Installing created file ../../../bin/linux-x86/../stexample.sh
> make[4]: *** No rule to make target
> `../../../bin/linux-x86/stexample.boot', needed by `buildInstall'.
> Stop.
> I can't find stexample.boot file.  Is it perchance stexample.src?
> Anyway, the file tree structure you are using is different from what I
> am used to and right now I feel a bit at a loss.
> Thank you,
> Zen
> > From: [email protected] [mailto:[email protected]]
> > Sent: Monday, January 17, 2011 9:53 AM
> > Cc: [email protected]; Szalata, Zenon M.
> > Subject: GigE driver for Area Detector
> > Hi all,
> > As a couple of people have asked for it, I've made a preliminary
> release
> > of the my areaDetector driver for GigE cameras on Linux based on the
> > aravis library. It is only tested on Prosilica/AVT cameras, although
> it
> > should work with all GigE vision compliant cameras but, as always,
> some
> > cameras are more compliant than others...
> > http://controls.diamond.ac.uk/downloads/support/aravisGigE
> > Once you have built the module, there are 2 helper programs in the
> > bin/linux-x86 directory, arv-show-devices will list all the GigE
> vision
> > cameras visible on the network, and dumpXml will dump their Genicam
> xml
> > files to disk. Please email me the outputs of these 2 programs if
> your
> > camera doesn't work properly.
> > Thanks,
> > Tom Cobb,
> > Diamond Light Source Ltd.
> > Diamond House
> > Harwell Science and Innovation Campus
> > Didcot
> > Oxfordshire
> > OX11 0DE
> > Tel +44 (0) 1235 778582
> > This e-mail and any attachments may contain confidential, copyright
> and or
> > privileged material, and are for the use of the intended addressee
> only. If you
> > are not the intended addressee or an authorised recipient of the
> addressee
> > please notify us of receipt by returning the e-mail and do not use,
> copy, retain,
> > distribute or disclose the information in or attached to the e-mail.
> > Any opinions expressed within this e-mail are those of the
individual
> and not
> > necessarily of Diamond Light Source Ltd.
> > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > are free from viruses and we cannot accept liability for any damage
> which you
> > may sustain as a result of software viruses which may be transmitted
> in or with
> > the message.
> > Diamond Light Source Limited (company no. 4375679). Registered in
> England
> > and Wales with its registered office at Diamond House, Harwell
> Science
> and
> > Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
RE: GigE driver for Area Detector Szalata, Zenon M.
GigE driver for Area Detector tom.cobb
RE: GigE driver for Area Detector Mark Rivers
Prev: RE: GigE driver for Area Detector Mark Rivers
Next: RE: GigE driver for Area Detector Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
