Hi Bruce,
On Monday 24 January 2011 23:14:02 Bruce Hill wrote:
> In all the bo record documentation I can find, record processing specifies:
> > if DOL is DB_LINK and OMSL is CLOSED_LOOP
> > * get value from DOL
> > * check for link alarm
> > * force VAL to be 0 or 1
> However, the boRecord.c source code for 3.14.9 and 3.14.11 does not do
> this. If you read a non-zero value from the DOL link, VAL and RVAL
> retain that non-zero value, even if it isn't a 1.
> Does anyone know if this is intentional, or a bug?
I think this is a bug, but I'm not certain whether it's in the code or the
documentation. I just checked the history all the way back to the beginning
of time (well, to when Marty first added the boRecord code to CVS in 1995) and
the VAL field has never been forced to be 0 or 1 during record processing.
Interestingly the forcing does happen at record initialization when DOL is a
constant.
If VAL is neither 0 nor 1 then ca_get as a string returns "Illegal_Value" and
RVAL is set to VAL; the behavior of RVAL is correct if the device support has
set MASK, RVAL is MASK for all non-zero VALs else zero.
Should we fix this in the 3.15 series? Does anybody know of any databases
that rely on this weird behavior?
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: bo Record not forcing VAL to 0 or 1 Bruce Hill
- bo Record not forcing VAL to 0 or 1 Bruce Hill
Re: CSS BOY Meter widget limits Paweł Prędki
RE: GigE driver for Area Detector Szalata, Zenon M.
<2011>
<2011>
