Hi Paweł,
On Tuesday 25 January 2011 09:17:08 Paweł Prędki wrote:
> The thing is the HIHI, HIGH, LOW and LOLO values are initialized in the
> record but BOY doesn't seem to be loading them. The record I'm referring
> to is as follows:
> record(ao,DISK:FORWARDING") {
> field(DESC,"Forwarding Throughput")
> field(DTYP,"Raw Soft Channel")
> field(EGU,"Gbps")
> field(OMSL,"supervisory")
> field(DRVL,0.0)
> field(DRVH,10.0)
> field(LOPR,0.0)
> field(HOPR,10.0)
> field(HIHI,8.0)
> field(HIGH,7.0);
> field(LOW, 1.0);
> field(LOLO,0.0)
The IOC also checks that you have something other than NO_ALARM in the
relevant xxSV field before it will provide the limit through CA, otherwise it
would have no way to tell whether your LOLO limit is an alarm limit or just
the default value for the LOLO field. You must set LLSV, LOSV, HISV and HHSV
if you want those values made available to BOY.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: CSS BOY Meter widget limits Paweł Prędki
- Re: CSS BOY Meter widget limits Kasemir, Kay
RE: CSS BOY Meter widget limits Mark Rivers
<2011>
<2011>
