Jimmy Johnson wrote:
I am planning on using a SoftIOC (R3.14.12) on Linux and will want
to run a control loop (about 1000 lines of C code spread across a few
custom records) deterministically at 100Hz. There will not be any other
user applications, in addition to the IOC, running on the box.
How stringent is your "deterministically at 100Hz" requirement?
EPICS itself shouldn't be an impediment, but the operating
system's real time capabilities will be. I would not expect a
non-realtime OS to do particularly well, though. A quick test on a
lightly loaded desktop machine with a 2.6.18 kernel gives . . .
My100HzTest 2011-01-20 09:20:36.881690 10
My100HzTest 2011-01-20 09:20:36.892685 10.01
My100HzTest 2011-01-20 09:20:36.903834 10.02
My100HzTest 2011-01-20 09:20:36.914830 10.03
My100HzTest 2011-01-20 09:20:36.925973 10.04
My100HzTest 2011-01-20 09:20:36.937975 10.05
My100HzTest 2011-01-20 09:20:36.950138 10.06
My100HzTest 2011-01-20 09:20:36.962171 10.07
My100HzTest 2011-01-20 09:20:36.974273 10.08
My100HzTest 2011-01-20 09:20:36.986281 10.09
My100HzTest 2011-01-20 09:20:36.997378 10.1
My100HzTest 2011-01-20 09:20:38.013803 11
My100HzTest 2011-01-20 09:20:38.024939 11.01
(a calc record incrementing by 0.01, with a custom SCAN of 0.01
seconds)
will show you that each iteration is going to happen slightly
later then ideal, in this case loosing 0.13 seconds over 100
iterations.
For a realtime OS like VxWorks, 100 Hz should be easy as long as
your processing can complete within that 0.01 second window
(dependent on your processor and your code and task priorities). I
don't have any experience with realtime extensions to Linux so
don't know how well that will perform, but if you are interested
in using Linux, I would start with that.
Steven Hartman
[email protected]
- Is it possible to have deterministic SoftIOC (R3.14.12) on Linux Jimmy Johnson
Re: Loading EPICS/RTEMS Apps from local filesystem on VME board Daron Chabot
Re: Is it possible to have deterministic SoftIOC (R3.14.12) on Linux David Kline
<2011>
<2011>
