Could be that bug. When I ran it on EPICS 3.14.11 it kept recursing and spitting out error messages until the stack overflowed.
possibly it’s this bug
https://bugs.launchpad.net/epics-base/+bug/693534
Jeff
______________________________________________________
Hi Mark,
I too observed this condition only yesterday, and have not had a chance to investigate. I was using New Focus Pico motors, not MDrive hardware.
If I exited the EPICS ioc-shell using the command, "exit", the problem appeared. This would lead me to start my search for code that has hooked into the iocsh exit routines (atexit ).
Note: things appeared to shutdown cleanly if I exited with a ctrl-c.
Perhaps someone more familiar with those different code paths can comment further and narrow down the search...?
-- dc
On Wed, Jan 19, 2011 at 2:58 PM, Vigder, Mark <[email protected]> wrote:
I'm yet another EPICS newbie. I've got a simple softIOC up and running
driving a couple of motors. Impressive software!
However I have a small problem. The IOC starts up fine and works
perfectly. But whenever I exit the IOC I get the following errors:
epicsEvent pthread_mutex_destroy failed: error Device or resource busy
epicsEvent pthread_cond_destroy failed: error Device or resource busy
My configuration is:
Ubuntu 10.04
EPICS base 3.14.12
ASYN 4-15
Motor 6-5-2
My st.cmd file is:
#!../../bin/linux-x86_64/motorTest
< envPaths
dbLoadDatabase "${TOP}/dbd/motorTest.dbd"
motorTest_registerRecordDeviceDriver pdbbase
dbLoadTemplate("motor.substitutions") # Loads two records
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=IOC:")
drvAsynIPPortConfigure("L0", "xxx.xxx.xxx.xxx:xxx",0,0,0)
MDriveSetup(1, 10)
MDriveConfig(0, "L0")
cd ${TOP}/iocBoot/${IOC}
iocInit
Any ideas on how I got into this problem? And what I do to get out of it
(and make sure it doesn't happen again)?
Thanks
Mark Vigder
Control System Architect
Canadian Neutron Beam Centre
- Problem exiting IOC Vigder, Mark
- Re: Problem exiting IOC Daron Chabot
- RE: Problem exiting IOC Jeff Hill
debian repository key change Davidsaver, Michael
Re: Changing DOL field from a subroutine record Andrew Johnson
<2011>
Changing DOL field from a subroutine record Luchini, Kristi L.
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
