1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EpicsCAServer and EpicsCAClient on Windows 7 64 bit
To: "'Bjorn Clausen'" <[email protected]>, <[email protected]>
Date: Fri, 14 Jan 2011 11:55:16 -0700
I understand that newer versions of LabView, if ordering certain options,
include an embedded ca client and portable ca server interfacing directly
with LV shared variables. As memory serves you will need the data-logging
and supervisorial control module, but I would check with David B to verify
this.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Bjorn Clausen
> Sent: Friday, January 14, 2011 10:45 AM
> To: [email protected]
> Subject: EpicsCAServer and EpicsCAClient on Windows 7 64 bit
> We have been using the ActiveX Interface for generating EPICS channels
> with
> Labview the last decade.
> It is described here: http://ics-web.sns.ornl.gov/kasemir/axca/index.html
> Obviously, it is not maintained any longer, but it has served us well...
> Today I tried installing it on my new Windows 7 64 bit machine, and it
> did
> not work :-(
> I can use the caget and caput commands to read and write to external
> epics
> channels from a cmd prompt, but when trying to generate epics channels
> from
> LabVIEW, it cannot connect to the EpicsCAServer.
> I checked in Component Services/Computers/My Computer/DCOM Config, and
> sure
> enough, there are no entries for EpicsCAServer and EpicsCACLient as there
> is
> on my old Windows XP system.
> I tried registering the services manually using:
> EpicsCAServer.exe -RegServer
> and
> EpicsCAClient.exe -RegServer
> But that did not do the trick... I guess it is understandable as the
> executables were made for Win2K...
> Does anyone have suggestions as how to move forward from here? Are there
> any
> other LabVIEW ports for EPICS out there?
> Thanks,
> Bjørn
> "TSPA" (Technology and Software Publicly Available)
> Bjørn Clausen, B.Sc., M.Sc., Ph.D.
> Technical Staff Member, SMARTS Instrument Scientist
> Los Alamos National Laboratory
> Lujan Center (LANSCE-LC)
> TA-53, Bldg. 622, Rm. 308
> P.O. Box 1663, MS H805
> Los Alamos, NM 87545
> Phone:  (505) 667-2944
> Fax:    (505) 665-2676
> E-mail: [email protected]
> Web:    http://public.lanl.gov/clausen
EpicsCAServer and EpicsCAClient on Windows 7 64 bit Bjorn Clausen
Prev: Re: EpicsCAServer and EpicsCAClient on Windows 7 64 bit Andrew Johnson
Next: GigE driver for Area Detector tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
