1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem using large arrays with Channel Access in EPICS 3.14.12
To: [email protected]
Date: Tue, 11 Jan 2011 15:43:22 -0600
On Tuesday 11 January 2011 15:21:32 Till Straumann wrote:
> Could be a limitation of the CA protocol
No, this is as a result of changes in src/rsrv between 3.14.11 and 3.14.12
because large arrays work fine in 3.14.11.
We introduced two major new features in the latest release, CA over TCP and
dynamic array sizing, and one of them (most probably the latter) has broken
the correct reporting of the element count.  The CA protocol solved the
problem of only a having a 16 bit m_count field a long time ago, but it looks
like that hack^H^H^H^Hsolution didn't get propagated into the latest code.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: Problem using large arrays with Channel Access in EPICS 3.14.12 Jeff Hill
RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Problem using large arrays with Channel Access in EPICS 3.14.12 Mark Rivers
Re: Problem using large arrays with Channel Access in EPICS 3.14.12 Till Straumann
Prev: RE: Problem using large arrays with Channel Access in EPICS 3.14.12 Mark Rivers
Next: Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Problem using large arrays with Channel Access in EPICS 3.14.12 Jeff Hill
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
