g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: streamDevice I/O Intr polling rate
From: Dimitrios Tsifakis <Dimitrios.Tsifakis@anu.edu.au>
To: tech-talk@aps.anl.gov
Date: Mon, 10 Jan 2011 16:26:18 +1100
Hello,
I am producing a protocol file for a home-made scaler and I am having a
problem. The scaler can be set up with a target count, then it can be
given a simple "Go" command to start counting. It will send a message to
the serial port when the required count target is reached. I am using an
I/O Intr SCAN record to search in the serial port data for that string.
It works for target counts that result in counting times of a second or
more. When the real counting time is less than a second, the reported
counting time is always more, usually around 1 second but at times a bit
less than that.
My question is, is there a way to increase the scan rate of the I/O Intr
record so that it detects the "target reached" string arriving on the
serial port quicker?
The counting times we expect are in the order of 300 ms. When I use
minicom to control the scaler directly, it sends the "target reached"
string as quickly as you would expect.
I am using base-3.14.12, asyn4-15 and StreamDevice-2-4, on linux.
Dimitris
Mail: Dimitrios.Tsifakis@anu.edu.au
WWW: http://wwwrsphysse.anu.edu.au/nuclear/
Phone: +61-2-6125 2088
Fax: +61-2-6125 0748
Dept. of Nuclear Physics
Research School of Physics and Engineering
Australian National University
Canberra ACT 0200  AUSTRALIA
Re: streamDevice I/O Intr polling rate Dirk Zimoch
Prev: RE: Adding readback zeroing to an asyn analog input Angus Gratton
Next: RE: MOXA terminal server emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: Re: CSS Data Browser Plot Problem John Dobbins
Next: Re: streamDevice I/O Intr polling rate Dirk Zimoch
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
