g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: pyepics callback function problem
To: tech-talk@aps.anl.gov
Date: Thu, 06 Jan 2011 11:52:30 +0100
Hello
I hope this is a right place to ask a question about pyepics.
I want to monitor two epic variables in a Python script. Interactive session gives this printout:
In [1]: import epics
In [2]: epics.__version__
Out[2]: '3.0.10'
In [5]: pll = epics.PV('LUCA:ENV:ENV_SC_PLL_MONITOR')
In [6]: print pll.info
== LUCA:ENV:ENV_SC_PLL_MONITOR  (native_enum) ==
  value      = 1
  char_value = 'LOCKED'
  count      = 1
  type       = enum
  host       = 10.0.4.51:5064
  access     = read/write
  status     = 0
  severity   = 0
  timestamp  = 1294304943.721 (2011-01-06 10:09:03.721306)
  enum strings:
      0 = UNLOCKED
      1 = LOCKED
  PV is internally monitored, with 0 user-defined callbacks:
In [16]: ventilator = epics.PV('LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR')
In [17]: print ventilator.info
== LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR  (native_double) ==
  value      = 4230
  char_value = '4230'
  count      = 1
  type       = double
  units      = RPM
  precision  = 0
  access     = read/write
  status     = 0
  severity   = 0
  timestamp  = 1294306643.047 (2011-01-06 10:37:23.046888)
  upper_ctrl_limit    = 0.0
  lower_ctrl_limit    = 0.0
  upper_disp_limit    = 0.0
  lower_disp_limit    = 0.0
  upper_alarm_limit   = 0.0
  lower_alarm_limit   = 0.0
  upper_warning_limit = 5500.0
  lower_warning_limit = 2000.0
So I have two varibles, one of enum type and one of double type with unit defined. They both change very slowly.
I wrote a simple program to monitor their value:
import sys
import time
from epics import PV
def callback_function(pvname=None, value=None, char_value=None, type=None,units=None, enum_strs=None, **kw):
   print "------Printout from callback ------"
   fmt = ' pvname \t = %s \n value \t\t = %s \n\
char_value \t = %s \n type \t\t = %s \n\
units \t\t = %s \n enum_strs \t = %s \n'
   print fmt % (pvname, value, char_value, type, units, enum_strs)
   print "----------------------------------\n"
pll = PV('LUCA:ENV:ENV_SC_PLL_MONITOR')
vent = PV('LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR')
pll.add_callback(callback_function)
pll.run_callbacks()
vent.add_callback(callback_function)
vent.run_callbacks()
while True:
   time.sleep(0.001)
But the results are strange :
pvname      = LUCA:ENV:ENV_SC_PLL_MONITOR
value          = 1
char_value      = 1
type          = enum
units          = None
enum_strs      = None
pvname      = LUCA:ENV:ENV_FRONT_VENT_ACT_MONITOR
value          = 4260.0
char_value      = 4260.0
type          = double
units          = None
enum_strs      = None
The problem is that only value, pvname and type is passed properly. char_value for pll varibale (enum type) should be LOCKED , also enum_strs shold be defined, and there is no units for vent variable.
Is this a bug  or am I doing something wrong ?
Best regards,
                 Janko Kolar
Re: pyepics callback function problem Matt Newville
Prev: Re: MOXA terminal server Dirk Zimoch
Next: Test, please ignore Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: UKIRT's Allen Bradley temperature problem - solved Maren Purves
Next: Re: pyepics callback function problem Matt Newville
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
