Hi Emma,
I have the DA-661. It has 16 ports, configurable for RS232, RS422, RS485
(2 wire or 4 wire). It's available with Linux or Windows OS. It allows
to run your own programs on the MOXA box. The Linux version comes with a
GNU tool chain which is already supported in EPICS R3.14.12.
I am not familiar with the NP6650. I had assumed you have similar
possibilities but I may be wrong.
Dirk
[email protected] wrote:
Hi Dirk,
That's interesting.. which model of MOXA are you using? I think the
6650 is Windows.
Emma
-----Original Message-----
Sent: 05 January 2011 15:59
To: Shepherd, Emma (DLSLtd,RAL,DIA)
Cc: [email protected]
Subject: Re: MOXA terminal server
Hi Emma,
Does your Moxa run on Linux or Windows? Mine is Linux and I use the
local program /bin/setinterface to select the mode (RS232, RS482 2
wire,
RS422, RS485 4 wire).
When running EPICS on the Moxa, you can do this from the EPICS startup
script with the 'system' command (3.14.12) or from inside StreamDevice
with the 'exec' command.
Dirk
Hi all,
We have recently been investigating options for controlling serial
devices via a terminal server. We particularly want the ability to
software switch between RS-232/RS-422/RS-485. One that has this
capability and seems to be generally recommended by the EPICS
community
is the MOXA NP6650 32-port device server.
However, after buying one to evaluate, we discovered an annoying
'feature': to change the settings of a serial port over the web
interface (baud rate etc) requires a reboot of the server, which of
course disrupts communications on all ports (and actually crashes my
soft IOC, though this might be a streamDevice issue...).
We wondered if anybody else has also come across this problem? If
so
have you found a way of getting around it, or do you have any other
recommendations? I have contacted MOXA technical support about the
issue, but they don't seem prepared to fix it.
Thanks in advance,
Emma
- MOXA terminal server emma.shepherd
- Re: MOXA terminal server Dirk Zimoch
- RE: MOXA terminal server emma.shepherd
UKIRT's Allen Bradley temperature problem - solved Maren Purves
pyepics callback function problem Janko Kolar
<2011>
Re: MOXA terminal server Eric Norum
how often do you use Tornado IDE tools for vxworks programming 王林
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
