1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: where are the vxworks os library files
To: [email protected]
Date: Tue, 4 Jan 2011 11:33:27 -0600
On Tuesday 04 January 2011 05:19:46 王林 wrote:
> I have been confused about where the vxworks os library files are for a
> long time, since the document EPICS-3.14 README said that you must have
> Tornado 2 installed if any of your target systems are vxWorks systems.
> Tornado 2 provides the cross-compiler and header files needed to build for
> these target systems, which means that we don't need library files for
> vxworks program development, and it seems very diffenent from Linux and
> Windows. After reading some documents, now can I understand it as this?
You are correct that the way we have traditionally done EPICS development for
vxWorks is different than for the workstation operating systems such as Linux
and Windows.
> The vxworks os libraries have already been compiled into the vxworks kernel
> image, the module will find the os libraries by the vxworks symbol table
> after loaded to target instead of linking on the host before loaded. Am I
> right? Some comment?
Correct, the IOC image that we build for vxWorks targets contains only the
EPICS code, and relies on the OS libraries having already been loaded as part
of the vxWorks boot image.
It should be possible to build an IOC image as a stand-alone bootable vxWorks
binary, but the EPICS build system does not contain the rules necessary to do
that and I'm not aware of anyone having actually done it.  This would require
linking with the vxWorks OS library files and thus would be more conventional
(we do build binaries for RTEMS like this).  If anyone manages to do this I
would be interested in adding the additional rules to future releases of EPICS
Base.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
where are the vxworks os library files 王林
Prev: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector tom.cobb
Next: record STAT = SCAN John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: where are the vxworks os library files 王林
Next: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector tom.cobb
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
