g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: where are the vxworks os library files
To: <tech-talk@aps.anl.gov>
Date: Tue, 4 Jan 2011 19:19:46 +0800
Hi All,
I have been confused about where the vxworks os library files are for a long time, since the document EPICS-3.14 README said that you must have Tornado 2 installed if any of your target systems are vxWorks systems. Tornado 2 provides the cross-compiler and header files needed to build for these target systems, which means that we don't need library files for vxworks program development, and it seems very diffenent from Linux and Windows.
After reading some documents, now can I understand it as this?
The vxworks os libraries have already been compiled into the vxworks kernel image, the module will find the os libraries by the vxworks symbol table after loaded to target instead of linking on the host before loaded.
Am I right? Some comment?
Lin Wang
Re: where are the vxworks os library files Andrew Johnson
Prev: RE: Adding readback zeroing to an asyn analog input Angus Gratton
Next: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Next: Re: where are the vxworks os library files Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
