1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: openmotif installtion problems.
Date: Sun, 19 Dec 2010 15:06:22 +0200
Hi all,
when I try to install the alarm handler or EDM or even the MEDM, I always got the same below error:
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/root/EPICS_TOP/extensions/src/alh1_2_24/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g  -I. -I../O.Common -I. -I../os/default -I.. -I../../../include/os/Linux -I../../../include -I../../../../base/include/os/Linux -I../../../../base/include  -I../../../include       -I../os/Linux -I../os/default -I/root/Desktop/openmotif-2.3.1/include -I/usr/include/X11    ../alCA.c
In file included from ../ax.h:27,
                 from ../alCA.c:24:
../alh.h:26:19: error: Xm/Xm.h: No such file or directory
../alh.h:27:26: error: Xm/RowColumn.h: No such file or directory
                 from ../alCA.c:24:
../alh.h:155: warning: parameter names (without types) in function declaration
../alh.h:156: error: expected specifier-qualifier-list before ‘XtPointer’
../alh.h:164: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
../alh.h:165: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘appContext’
../alh.h:166: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘topLevelShell’
../alh.h:167: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘productDescriptionShell’
../alh.h:168: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ALH_pixmap’
../alh.h:176: error: expected specifier-qualifier-list before ‘XtIntervalId’
In file included from ../ax.h:28,
                 from ../alCA.c:24:
../axSubW.h:32: error: expected specifier-qualifier-list before ‘Widget’
In file included from ../ax.h:29,
                 from ../alCA.c:24:
../line.h:52: error: expected specifier-qualifier-list before ‘Widget’
In file included from ../ax.h:30,
                 from ../alCA.c:24:
../alLib.h:61: error: expected specifier-qualifier-list before ‘XtIntervalId’
../alLib.h:111: error: expected specifier-qualifier-list before ‘XtIntervalId’
../alLib.h:128: error: expected specifier-qualifier-list before ‘XtIntervalId’
../alLib.h:151: error: expected specifier-qualifier-list before ‘XtIntervalId’
In file included from ../alCA.c:24:
../ax.h:54: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:71: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:73: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:121: error: expected declaration specifiers or ‘...’ before ‘XmFileSelectionBoxCallbackStruct’
../ax.h:122: error: expected declaration specifiers or ‘...’ before ‘XmFileSelectionBoxCallbackStruct’
../ax.h:130: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:138: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
../ax.h:140: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
../ax.h:142: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
../ax.h:144: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
../ax.h:161: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:394: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:395: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:397: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
../ax.h:411: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
make[1]: *** [alCA.o] Error 1
make[1]: Leaving directory `/root/EPICS_TOP/extensions/src/alh1_2_24/O.linux-x86'
make: *** [install.linux-x86] Error 2
which means Xm.h is missing, and this requires to install open motif,
my question how do we install openmotif and from where we get the correct version and where do we install
it in  reference with the EDM or MEDM directory? Any suggestions ?
best resgards,
saed.
Re: openmotif installtion problems. Mauro Giacchini
Re: openmotif installtion problems. Noboru Yamamoto
Prev: RE: Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express Wang Xiaoqiang
Next: Re: openmotif installtion problems. Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Patch for EDM Crashes on x86_64 Sebastian Marsching
ANJ, 19 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
