1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express
To: "Chen Xue" <[email protected]>, <[email protected]>
Date: Sat, 18 Dec 2010 15:39:02 +0100
Because GnuWin32 has also link.exe, make.exe looks first from its current directoy and that overrides link.exe from VC.
Either rename it or remove it in case you dont GnuWin32 at all.
Best,
Xiaoqiang
-----Original Message-----
Sent: Fri 12/17/2010 9:14 PM
To: [email protected]
Subject: Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express
I build the EPICS 3.14.12 in windows 7 OS. The software I used is as
below. After unzip the base 3.14.12, I modify the file, win32.bat in
base\startup\, to set the specific environment variable in my computer
and run it before build. The special things I found is when I made a
copy of gnu make "make.exe" file in the epics base folder. It builds
successfully. But without it, it has error message because it calls gnu
make link.exe instead of VC++ link.exe.
1. GNU Make (gnuwin32 v3.8.1)
2. ActivePerl 5.12
3. MS VS C++ 2010 Express
4. epics base 3.14.12
Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express Chen Xue
Prev: Re: Breakpoint Tables David Dudley
Next: openmotif installtion problems. Saed Abu Ghannam
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Build EPICS 3.14.12 in windows 7 by MS VC++ 2010 Express Chen Xue
Next: Patch for EDM Crashes on x86_64 Sebastian Marsching
ANJ, 19 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
