Please check if the attached file fixes the error. The bug in the Tornado 1 WindRiver g++ is that it chokes when asked to call methods of a temporary object. Dirk Benjamin Franksen wrote: ...triggers a bug in our old vxworks cross-compilers. This is the relevant part of the make output: /*************************************************************** * StreamDevice Support * * * * (C) 1999 Dirk Zimoch ([email protected]) * * (C) 2005 Dirk Zimoch ([email protected]) * * * * This is the kernel of StreamDevice. * * Please refer to the HTML files in ../doc/ for a detailed * * documentation. * * * * If you do any changes in this file, you are not allowed to * * redistribute it any more. If there is a bug or a missing * * feature, send me an email and/or your patch. If I accept * * your changes, they will go to the next release. * * * * DISCLAIMER: If this software breaks something or harms * * someone, it's your problem. * * * ***************************************************************/ #include "StreamCore.h" #include "StreamError.h" #include <ctype.h> #include <stdlib.h> enum Commands { end_cmd, in_cmd, out_cmd, wait_cmd, event_cmd, exec_cmd, connect_cmd, disconnect_cmd }; const char* commandStr[] = { "end", "in", "out", "wait", "event", "exec", "connect", "disconnect" }; inline const char* commandName(unsigned char i) { return i >= sizeof(commandStr)/sizeof(char*) ? "invalid" : commandStr[i]; } /// debug functions ///////////////////////////////////////////// static char* printCommands(StreamBuffer& buffer, const char* c) { unsigned long timeout; unsigned long eventnumber; unsigned short cmdlen; while (1) { switch(*c++) { case end_cmd: return buffer(); case in_cmd: buffer.append(" in \""); c = StreamProtocolParser::printString(buffer, c); buffer.append("\";\n"); break; case out_cmd: buffer.append(" out \""); c = StreamProtocolParser::printString(buffer, c); buffer.append("\";\n"); break; case wait_cmd: timeout = extract<unsigned long>(c); buffer.printf(" wait %ld;\n # ms", timeout); break; case event_cmd: eventnumber = extract<unsigned long>(c); timeout = extract<unsigned long>(c); buffer.printf(" event(%ld) %ld; # ms\n", eventnumber, timeout); break; case exec_cmd: buffer.append(" exec \""); cmdlen = extract<unsigned short>(c); c = StreamProtocolParser::printString(buffer, c); buffer.append("\";\n"); break; case connect_cmd: timeout = extract<unsigned long>(c); buffer.printf(" connect %ld; # ms\n", timeout); break; case disconnect_cmd: buffer.append(" disconnect;\n"); break; default: buffer.append("\033[31;1mGARBAGE: "); c = StreamProtocolParser::printString(buffer, c-1); buffer.append("\033[0m\n"); } } } void StreamCore:: printProtocol() { StreamBuffer buffer; printf("%s {\n", protocolname()); printf(" extraInput = %s;\n", (flags & IgnoreExtraInput) ? "ignore" : "error"); printf(" lockTimeout = %ld; # ms\n", lockTimeout); printf(" readTimeout = %ld; # ms\n", readTimeout); printf(" replyTimeout = %ld; # ms\n", replyTimeout); printf(" writeTimeout = %ld; # ms\n", writeTimeout); printf(" pollPeriod = %ld; # ms\n", pollPeriod); printf(" maxInput = %ld; # bytes\n", maxInput); StreamProtocolParser::printString(buffer.clear(), inTerminator()); printf(" inTerminator = \"%s\";\n", buffer()); StreamProtocolParser::printString(buffer.clear(), outTerminator()); printf(" outTerminator = \"%s\";\n", buffer()); StreamProtocolParser::printString(buffer.clear(), separator()); printf(" separator = \"%s\";\n", buffer()); if (onInit) printf(" @Init {\n%s }\n", printCommands(buffer.clear(), onInit())); if (onReplyTimeout) printf(" @ReplyTimeout {\n%s }\n", printCommands(buffer.clear(), onReplyTimeout())); if (onReadTimeout) printf(" @ReadTimeout {\n%s }\n", printCommands(buffer.clear(), onReadTimeout())); if (onWriteTimeout) printf(" @WriteTimeout {\n%s }\n", printCommands(buffer.clear(), onWriteTimeout())); if (onMismatch) printf(" @Mismatch {\n%s }\n", printCommands(buffer.clear(), onMismatch())); debug("StreamCore::printProtocol: commands=%s\n", commands.expand()()); printf("\n%s}\n", printCommands(buffer.clear(), commands())); } /////////////////////////////////////////////////////////////////////////// StreamCore* StreamCore::first = NULL; StreamCore:: StreamCore() { businterface = NULL; flags = None; next = NULL; unparsedInput = false; // add myself to list of streams StreamCore** pstream; for (pstream = &first; *pstream; pstream = &(*pstream)->next); *pstream = this; } StreamCore:: ~StreamCore() { debug("~StreamCore(%s) %p\n", name(), (void*)this); releaseBus(); // remove myself from list of all streams StreamCore** pstream; for (pstream = &first; *pstream; pstream = &(*pstream)->next) { if (*pstream == this) { *pstream = next; break; } } } bool StreamCore:: attachBus(const char* busname, int addr, const char* param) { releaseBus(); businterface = StreamBusInterface::find(this, busname, addr, param); if (!businterface) { error("Businterface '%s' not found for '%s'\n", busname, name()); return false; } debug("StreamCore::attachBus(busname=\"%s\", addr=%i, param=\"%s\") businterface=%p\n", busname, addr, param, (void*)businterface); return true; } void StreamCore:: releaseBus() { if (businterface) { if (flags & BusOwner) { busUnlock(); } busRelease(); businterface = NULL; } } // Parse the protocol bool StreamCore:: parse(const char* filename, const char* _protocolname) { protocolname = _protocolname; // extract substitutions from protocolname "name(sub1,sub2)" int i = protocolname.find('('); if (i >= 0) { while (i >= 0) { protocolname[i] = '\0'; // replace '(' and ',' with '\0' i = protocolname.find(',', i+1); } // should have closing parentheses if (protocolname[-1] != ')') { error("Missing ')' after substitutions '%s'\n", _protocolname); return false; } protocolname.truncate(-1); // remove ')' } StreamProtocolParser::Protocol* protocol; protocol = StreamProtocolParser::getProtocol(filename, protocolname); if (!protocol) { error("while reading protocol '%s' for '%s'\n", protocolname(), name()); return false; } if (!compile(protocol)) { delete protocol; error("while compiling protocol '%s' for '%s'\n", _protocolname, name()); return false; } delete protocol; return true; } bool StreamCore:: compile(StreamProtocolParser::Protocol* protocol) { const char* extraInputNames [] = {"error", "ignore", NULL}; // default values for protocol variables flags &= ~IgnoreExtraInput; lockTimeout = 5000; readTimeout = 100; replyTimeout = 1000; writeTimeout = 100; maxInput = 0; pollPeriod = 1000; inTerminatorDefined = false; outTerminatorDefined = false; unsigned short ignoreExtraInput = false; if (!protocol->getEnumVariable("extrainput", ignoreExtraInput, extraInputNames)) { return false; } if (ignoreExtraInput) flags |= IgnoreExtraInput; if (!(protocol->getNumberVariable("locktimeout", lockTimeout) && protocol->getNumberVariable("readtimeout", readTimeout) && protocol->getNumberVariable("replytimeout", replyTimeout) && protocol->getNumberVariable("writetimeout", writeTimeout) && protocol->getNumberVariable("maxinput", maxInput) && // use replyTimeout as default for pollPeriod protocol->getNumberVariable("replytimeout", pollPeriod) && protocol->getNumberVariable("pollperiod", pollPeriod))) { return false; } if (!(protocol->getStringVariable("terminator", inTerminator, &inTerminatorDefined) && protocol->getStringVariable("terminator", outTerminator, &outTerminatorDefined) && protocol->getStringVariable("interminator", inTerminator, &inTerminatorDefined) && protocol->getStringVariable("outterminator", outTerminator, &outTerminatorDefined) && protocol->getStringVariable("separator", separator))) { return false; } if (!(protocol->getCommands(NULL, commands, this) && protocol->getCommands("@init", onInit, this) && protocol->getCommands("@writetimeout", onWriteTimeout, this) && protocol->getCommands("@replytimeout", onReplyTimeout, this) && protocol->getCommands("@readtimeout", onReadTimeout, this) && protocol->getCommands("@mismatch", onMismatch, this))) { return false; } return protocol->checkUnused(); } bool StreamCore:: compileCommand(StreamProtocolParser::Protocol* protocol, StreamBuffer& buffer, const char* command, const char*& args) { unsigned long timeout = 0; if (strcmp(command, commandStr[in_cmd]) == 0) { buffer.append(in_cmd); if (!protocol->compileString(buffer, args, ScanFormat, this)) { return false; } buffer.append(StreamProtocolParser::eos); return true; } if (strcmp(command, commandStr[out_cmd]) == 0) { buffer.append(out_cmd); if (!protocol->compileString(buffer, args, PrintFormat, this)) { return false; } buffer.append(StreamProtocolParser::eos); return true; } if (strcmp(command, commandStr[wait_cmd]) == 0) { buffer.append(wait_cmd); if (!protocol->compileNumber(timeout, args)) { return false; } buffer.append(&timeout, sizeof(timeout)); return true; } if (strcmp(command, commandStr[event_cmd]) == 0) { if (!busSupportsEvent()) { error(getLineNumber(command), protocol->filename(), "Events not supported by businterface.\n"); return false; } unsigned long eventmask = 0xffffffff; buffer.append(event_cmd); if (*args == '(') { if (!protocol->compileNumber(eventmask, ++args)) { return false; } if (*args != ')') { error(getLineNumber(command), protocol->filename(), "Expect ')' instead of: '%s'\n", args); return false; } args++; } buffer.append(&eventmask, sizeof(eventmask)); if (*args) { if (!protocol->compileNumber(timeout, args)) { return false; } } buffer.append(&timeout, sizeof(timeout)); return true; } if (strcmp(command, commandStr[exec_cmd]) == 0) { buffer.append(exec_cmd); if (!protocol->compileString(buffer, args, NoFormat, this)) { return false; } buffer.append(StreamProtocolParser::eos); return true; } if (strcmp(command, commandStr[connect_cmd]) == 0) { buffer.append(connect_cmd); if (!protocol->compileNumber(timeout, args)) { return false; } buffer.append(&timeout, sizeof(timeout)); return true; } if (strcmp(command, commandStr[disconnect_cmd]) == 0) { buffer.append(disconnect_cmd); return true; } error(getLineNumber(command), protocol->filename(), "Unknown command name '%s'\n", command); return false; } // Run the protocol // Input and events may come asynchonously from the bus driver // Especially in the sequence 'out "request"; in "reply";' the // reply can come before the 'in' command has actually started. // For asyncronous protocols, input can come at any time. // Thus, we must always accept input and event while the protocol // is running or when asyncronous mode is active. // Early input and event must be buffered until 'in' or 'event' // start. An 'out' command must discard any early input to avoid // problems with late input from aborted protocols. // Async mode ends on Abort or Error or if another command comes // after the asynchronous 'in' command. // Input can be discarded when it is not accepted any more, i.e. // at the end of syncronous protocols and when an asynchronous // mode ends (but not when 'in'-only protocol finishes normally). bool StreamCore:: startProtocol(StartMode startMode) { MutexLock lock(this); debug("StreamCore::startProtocol(%s, startMode=%s)\n", name(), startMode == StartNormal ? "StartNormal" : startMode == StartInit ? "StartInit" : startMode == StartAsync ? "StartAsync" : "Invalid"); if (!businterface) { error("%s: No businterface attached\n", name()); return false; } flags &= ~ClearOnStart; switch (startMode) { case StartInit: flags |= InitRun; break; case StartAsync: if (!busSupportsAsyncRead()) { error("%s: Businterface does not support async mode\n", name()); return false; } flags |= AsyncMode; break; case StartNormal: break; } if (!commands) { error ("%s: No protocol loaded\n", name()); return false; } commandIndex = (startMode == StartInit) ? onInit() : commands(); runningHandler = Success; protocolStartHook(); return evalCommand(); } void StreamCore:: finishProtocol(ProtocolResult status) { if (flags & BusPending) { error("StreamCore::finishProtocol(%s): Still waiting for %s%s%s\n", name(), flags & LockPending ? "lockSuccess() " : "", flags & WritePending ? "writeSuccess() " : "", flags & WaitPending ? "timerCallback()" : ""); status = Fault; } //// flags &= ~(AcceptInput|AcceptEvent); if (runningHandler) { // get original error status if (status == Success) status = runningHandler; } else { // save original error status runningHandler = status; // look for error handler char* handler; switch (status) { case Success: handler = NULL; break; case WriteTimeout: handler = onWriteTimeout(); break; case ReplyTimeout: handler = onReplyTimeout(); break; case ReadTimeout: handler = onReadTimeout(); break; case ScanError: handler = onMismatch(); /* reparse old input if first command in handler is 'in' */ if (*handler == in_cmd) { debug("reparsing input \"%s\"\n", inputLine.expand()()); commandIndex = handler + 1; if (matchInput()) { evalCommand(); return; } handler = NULL; break; } break; default: // get rid of all the rubbish whe might have collected unparsedInput = false; inputBuffer.clear(); handler = NULL; } if (handler) { debug("starting exception handler\n"); // execute handler commandIndex = handler; evalCommand(); return; } } debug("StreamCore::finishProtocol(%s, status=%s) %sbus owner\n", name(), status==0 ? "Success" : status==1 ? "LockTimeout" : status==2 ? "WriteTimeout" : status==3 ? "ReplyTimeout" : status==4 ? "ReadTimeout" : status==5 ? "ScanError" : status==6 ? "FormatError" : status==7 ? "Abort" : status==8 ? "Fault" : "Invalid", flags & BusOwner ? "" : "not "); if (flags & BusOwner) { busUnlock(); flags &= ~BusOwner; } busFinish(); flags &= ~(AcceptInput|AcceptEvent); protocolFinishHook(status); } bool StreamCore:: evalCommand() { if (flags & BusPending) { error("StreamCore::evalCommand(%s): Still waiting for %s%s%s", name(), flags & LockPending ? "lockSuccess() " : "", flags & WritePending ? "writeSuccess() " : "", flags & WaitPending ? "timerCallback()" : ""); return false; } activeCommand = commandIndex; debug("StreamCore::evalCommand(%s): activeCommand = %s\n", name(), commandName(*activeCommand)); switch (*commandIndex++) { case out_cmd: //// flags &= ~(AcceptInput|AcceptEvent); return evalOut(); case in_cmd: //// flags &= ~AcceptEvent; return evalIn(); case wait_cmd: //// flags &= ~(AcceptInput|AcceptEvent); return evalWait(); case event_cmd: //// flags &= ~AcceptInput; return evalEvent(); case exec_cmd: return evalExec(); case end_cmd: finishProtocol(Success); return true; case connect_cmd: return evalConnect(); case disconnect_cmd: return evalDisconnect(); default: error("INTERNAL ERROR (%s): illegal command code 0x%02x\n", name(), *activeCommand); flags &= ~BusPending; finishProtocol(Fault); return false; } } // Handle 'out' command bool StreamCore:: evalOut() { // flush all unread input unparsedInput = false; inputBuffer.clear(); if (!formatOutput()) { finishProtocol(FormatError); return false; } outputLine.append(outTerminator); debug ("StreamCore::evalOut: outputLine = \"%s\"\n", outputLine.expand()()); if (*commandIndex == in_cmd) // prepare for early input { flags |= AcceptInput; } if (*commandIndex == event_cmd) // prepare for early event { flags |= AcceptEvent; } if (!(flags & BusOwner)) { debug ("StreamCore::evalOut(%s): lockRequest(%li)\n", name(), flags & InitRun ? 0 : lockTimeout); flags |= LockPending; if (!busLockRequest(flags & InitRun ? 0 : lockTimeout)) { return false; } return true; } flags |= WritePending; if (!busWriteRequest(outputLine(), outputLine.length(), writeTimeout)) { return false; } return true; } bool StreamCore:: formatOutput() { char command; const char* fieldName = NULL; const char* formatstring; int formatstringlen; outputLine.clear(); while ((command = *commandIndex++) != StreamProtocolParser::eos) { switch (command) { case StreamProtocolParser::format_field: { debug("StreamCore::formatOutput(%s): StreamProtocolParser::redirect_format\n", name()); // code layout: // field <eos> addrlen AddressStructure formatstring <eos> StreamFormat [info] fieldName = commandIndex; commandIndex += strlen(commandIndex)+1; unsigned short addrlen = extract<unsigned short>(commandIndex); fieldAddress.set(commandIndex, addrlen); commandIndex += addrlen; } case StreamProtocolParser::format: { // code layout: // formatstring <eos> StreamFormat [info] formatstring = commandIndex; // jump after <eos> while (*commandIndex) { if (*commandIndex == esc) commandIndex++; commandIndex++; } formatstringlen = commandIndex-formatstring; commandIndex++; StreamFormat fmt = extract<StreamFormat>(commandIndex); fmt.info = commandIndex; // point to info string commandIndex += fmt.infolen; #ifndef NO_TEMPORARY debug("StreamCore::formatOutput(%s): format = %%%s\n", name(), StreamBuffer(formatstring, formatstringlen).expand()()); #endif if (fmt.type == pseudo_format) { if (!StreamFormatConverter::find(fmt.conv)-> printPseudo(fmt, outputLine)) { error("%s: Can't print pseudo value '%%%s'\n", name(), formatstring); return false; } continue; } flags &= ~Separator; if (!formatValue(fmt, fieldAddress ? fieldAddress() : NULL)) { StreamBuffer formatstr(formatstring, formatstringlen); if (fieldAddress) error("%s: Cannot format field '%s' with '%%%s'\n", name(), fieldName, formatstr.expand()()); else error("%s: Cannot format value with '%%%s'\n", name(), formatstr.expand()()); return false; } fieldAddress.clear(); continue; } case StreamProtocolParser::whitespace: outputLine.append(' '); case StreamProtocolParser::skip: continue; case esc: // escaped literal byte command = *commandIndex++; default: // literal byte outputLine.append(command); } } return true; } void StreamCore:: printSeparator() { if (!(flags & Separator)) { flags |= Separator; return; } if (!separator) return; long i = 0; for (; i < separator.length(); i++) { switch (separator[i]) { case StreamProtocolParser::whitespace: outputLine.append(' '); // print single space case StreamProtocolParser::skip: continue; case esc: // escaped literal byte i++; default: // literal byte outputLine.append(separator[i]); } } } bool StreamCore:: printValue(const StreamFormat& fmt, long value) { if (fmt.type != long_format && fmt.type != enum_format) { error("%s: printValue(long) called with %%%c format\n", name(), fmt.conv); return false; } printSeparator(); if (!StreamFormatConverter::find(fmt.conv)-> printLong(fmt, outputLine, value)) { error("%s: Formatting value %li failed\n", name(), value); return false; } debug("StreamCore::printValue(%s, long): \"%s\"\n", name(), outputLine.expand()()); return true; } bool StreamCore:: printValue(const StreamFormat& fmt, double value) { if (fmt.type != double_format) { error("%s: printValue(double) called with %%%c format\n", name(), fmt.conv); return false; } printSeparator(); if (!StreamFormatConverter::find(fmt.conv)-> printDouble(fmt, outputLine, value)) { error("%s: Formatting value %#g failed\n", name(), value); return false; } debug("StreamCore::printValue(%s, double): \"%s\"\n", name(), outputLine.expand()()); return true; } bool StreamCore:: printValue(const StreamFormat& fmt, char* value) { if (fmt.type != string_format) { error("%s: printValue(char*) called with %%%c format\n", name(), fmt.conv); return false; } printSeparator(); if (!StreamFormatConverter::find(fmt.conv)-> printString(fmt, outputLine, value)) { StreamBuffer buffer(value); error("%s: Formatting value \"%s\" failed\n", name(), buffer.expand()()); return false; } debug("StreamCore::printValue(%s, char*): \"%s\"\n", name(), outputLine.expand()()); return true; } void StreamCore:: lockCallback(StreamIoStatus status) { MutexLock lock(this); debug("StreamCore::lockCallback(%s, status=%s)\n", name(), status ? "Timeout" : "Success"); if (!(flags & LockPending)) { error("StreamCore::lockCallback(%s) called unexpectedly\n", name()); return; } flags &= ~LockPending; flags |= BusOwner; if (status != StreamIoSuccess) { finishProtocol(LockTimeout); return; } flags |= WritePending; if (!busWriteRequest(outputLine(), outputLine.length(), writeTimeout)) { finishProtocol(Fault); } } void StreamCore:: writeCallback(StreamIoStatus status) { MutexLock lock(this); debug("StreamCore::writeCallback(%s, status=%s)\n", name(), status ? "Timeout" : "Success"); if (!(flags & WritePending)) { error("StreamCore::writeCallback(%s) called unexpectedly\n", name()); return; } flags &= ~WritePending; if (status != StreamIoSuccess) { finishProtocol(WriteTimeout); return; } evalCommand(); } const char* StreamCore:: getOutTerminator(size_t& length) { if (outTerminatorDefined) { length = outTerminator.length(); return outTerminator(); } else { length = 0; return NULL; } } // Handle 'in' command bool StreamCore:: evalIn() { flags |= AcceptInput; long expectedInput; expectedInput = maxInput; if (unparsedInput) { // handle early input debug("StreamCore::evalIn(%s): early input: %s\n", name(), inputBuffer.expand()()); expectedInput = readCallback(lastInputStatus, NULL, 0); if (!expectedInput) { // no more input needed return true; } } if (flags & AsyncMode) { // release bus if (flags & BusOwner) { debug("StreamCore::evalIn(%s): unlocking bus\n", name()); busUnlock(); flags &= ~BusOwner; } busReadRequest(pollPeriod, readTimeout, expectedInput, true); return true; } busReadRequest(replyTimeout, readTimeout, expectedInput, false); // continue with readCallback() in another thread return true; } long StreamCore:: readCallback(StreamIoStatus status, const void* input, long size) // returns number of bytes to read additionally { if (status < 0 || status > StreamIoFault) { error("StreamCore::readCallback(%s) called with illegal StreamIoStatus %d\n", name(), status); return 0; } MutexLock lock(this); lastInputStatus = status; #ifndef NO_TEMPORARY debug("StreamCore::readCallback(%s, status=%s input=\"%s\", size=%ld)\n", name(), StreamIoStatusStr[status], StreamBuffer(input, size).expand()(), size); #endif if (!(flags & AcceptInput)) { #ifdef NO_TEMPORARY error("StreamCore::readCallback(%s, %s) called unexpectedly\n", name(), StreamIoStatusStr[status]); #else error("StreamCore::readCallback(%s, %s, \"%s\") called unexpectedly\n", name(), StreamIoStatusStr[status], StreamBuffer(input, size).expand()()); #endif return 0; } //// flags &= ~AcceptInput; switch (status) { case StreamIoTimeout: // timeout is valid end if we have no terminator // and number of input bytes is not limited if (!inTerminator && !maxInput) { status = StreamIoEnd; } // else timeout might be ok if we find a terminator break; case StreamIoSuccess: case StreamIoEnd: break; case StreamIoNoReply: if (flags & AsyncMode) { // just restart in asyn mode debug("StreamCore::readCallback(%s) no async input: just restart\n", name()); evalIn(); return 0; } error("%s: No reply from device within %ld ms\n", name(), replyTimeout); inputBuffer.clear(); finishProtocol(ReplyTimeout); return 0; case StreamIoFault: error("%s: I/O error after reading %ld byte%s: \"%s%s\"\n", name(), inputBuffer.length(), inputBuffer.length()==1 ? "" : "s", inputBuffer.length() > 20 ? "..." : "", inputBuffer.expand(-20,20)()); finishProtocol(Fault); return 0; } inputBuffer.append(input, size); debug("StreamCore::readCallback(%s) inputBuffer=\"%s\", size %ld\n", name(), inputBuffer.expand()(), inputBuffer.length()); if (*activeCommand != in_cmd) { // early input, stop here and wait for in command // -- Should we limit size of inputBuffer? -- if (inputBuffer) unparsedInput = true; return 0; } // prepare to parse the input const char *commandStart = commandIndex; long end = -1; long termlen = 0; if (inTerminator) { // look for terminator // performance issue for long inputs that come in chunks: // do not parse old chunks again or performance decreases to O(n^2) // but make sure to get all terminators in multi-line input long start; if (unparsedInput) { // multi-line input sets 'unparsedInput' and removes the line // remaining unparsed lines are left at start of inputBuffer start = 0; } else { // long line does not set 'unparsedInput' but keeps // already parsed chunks in inputBuffer // start parsing at beginning of new data // but beware of split terminators start = inputBuffer.length() - size - inTerminator.length(); if (start < 0) start = 0; } end = inputBuffer.find(inTerminator, start); if (end >= 0) { termlen = inTerminator.length(); debug("StreamCore::readCallback(%s) inTerminator %s at position %ld\n", name(), inTerminator.expand()(), end); } else { debug("StreamCore::readCallback(%s) inTerminator %s not found\n", name(), inTerminator.expand()()); } } if (status == StreamIoEnd && end < 0) { // no terminator but end flag debug("StreamCore::readCallback(%s) end flag received\n", name()); end = inputBuffer.length(); } if (maxInput && end < 0 && (long)maxInput <= inputBuffer.length()) { // no terminator but maxInput bytes read debug("StreamCore::readCallback(%s) maxInput size reached\n", name()); end = maxInput; } if (maxInput && end > (long)maxInput) { // limit input length to maxInput (ignore terminator) end = maxInput; termlen = 0; } if (end >= 0) { // be forgiving with timeout because end is found if (status == StreamIoTimeout) status = StreamIoEnd; } if (end < 0) { // no end found if (status != StreamIoTimeout) { // input is incomplete - wait for more debug("StreamCore::readCallback(%s) wait for more input\n", name()); flags |= AcceptInput; if (maxInput) return maxInput - inputBuffer.length(); else return -1; } // try to parse what we got end = inputBuffer.length(); if (flags & AsyncMode) { debug("StreamCore::readCallback(%s) async timeout: just restart\n", name()); unparsedInput = false; inputBuffer.clear(); commandIndex = commandStart; evalIn(); return 0; } else { error("%s: Timeout after reading %ld byte%s \"%s%s\"\n", name(), end, end==1 ? "" : "s", end > 20 ? "..." : "", inputBuffer.expand(-20)()); } } inputLine.set(inputBuffer(), end); debug("StreamCore::readCallback(%s) input line: \"%s\"\n", name(), inputLine.expand()()); bool matches = matchInput(); inputBuffer.remove(end + termlen); if (inputBuffer) { debug("StreamCore::readCallback(%s) unpared input left: \"%s\"\n", name(), inputBuffer.expand()()); unparsedInput = true; } else { unparsedInput = false; } if (!matches) { if (status == StreamIoTimeout) { // we have not forgotten the timeout finishProtocol(ReadTimeout); return 0; } if (flags & AsyncMode) { debug("StreamCore::readCallback(%s) async match failure: just restart\n", name()); commandIndex = commandStart; evalIn(); return 0; } debug("StreamCore::readCallback(%s) match failure\n", name()); finishProtocol(ScanError); return 0; } if (status == StreamIoTimeout) { // we have not forgotten the timeout finishProtocol(ReadTimeout); return 0; } // end input mode and do next command //// flags &= ~(AsyncMode|AcceptInput); // -- should we tell someone that input has finished? -- evalCommand(); return 0; } bool StreamCore:: matchInput() { /* Don't write messages about matching errors if either in asynchronous mode (then we just wait for new matching input) or if @mismatch handler is installed and starts with 'in' (then we reparse the input). */ char command; const char* fieldName = NULL; const char* formatstring; int formatstringlen; consumedInput = 0; while ((command = *commandIndex++) != StreamProtocolParser::eos) { switch (command) { case StreamProtocolParser::format_field: { // code layout: // field <StreamProtocolParser::eos> addrlen AddressStructure formatstring <StreamProtocolParser::eos> StreamFormat [info] fieldName = commandIndex; commandIndex += strlen(commandIndex)+1; unsigned short addrlen = extract<unsigned short>(commandIndex); fieldAddress.set(commandIndex, addrlen); commandIndex += addrlen; } case StreamProtocolParser::format: { int consumed; // code layout: // formatstring <eos> StreamFormat [info] formatstring = commandIndex; // jump after <eos> while (*commandIndex) { if (*commandIndex == esc) commandIndex++; commandIndex++; } formatstringlen = commandIndex-formatstring; commandIndex++; StreamFormat fmt = extract<StreamFormat>(commandIndex); fmt.info = commandIndex; // point to info string commandIndex += fmt.infolen; #ifndef NO_TEMPORARY debug("StreamCore::matchInput(%s): format = %%%s\n", name(), StreamBuffer(formatstring, formatstringlen).expand()()); #endif if (fmt.flags & skip_flag || fmt.type == pseudo_format) { long ldummy; double ddummy; switch (fmt.type) { case long_format: case enum_format: consumed = StreamFormatConverter::find(fmt.conv)-> scanLong(fmt, inputLine(consumedInput), ldummy); break; case double_format: consumed = StreamFormatConverter::find(fmt.conv)-> scanDouble(fmt, inputLine(consumedInput), ddummy); break; case string_format: consumed = StreamFormatConverter::find(fmt.conv)-> scanString(fmt, inputLine(consumedInput), NULL, 0); break; case pseudo_format: // pass complete input consumed = StreamFormatConverter::find(fmt.conv)-> scanPseudo(fmt, inputLine, consumedInput); break; default: error("INTERNAL ERROR (%s): illegal format.type 0x%02x\n", name(), fmt.type); return false; } if (consumed < 0) { if (fmt.flags & default_flag) { consumed = 0; } else { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { error("%s: Input \"%s%s\" does not match format %%%s\n", name(), inputLine.expand(consumedInput, 20)(), inputLine.length()-consumedInput > 20 ? "..." : "", formatstring); } return false; } } consumedInput += consumed; break; } if (fmt.flags & compare_flag) { outputLine.clear(); flags &= ~Separator; if (!formatValue(fmt, fieldAddress ? fieldAddress() : NULL)) { StreamBuffer formatstr(formatstring, formatstringlen); if (fieldAddress) error("%s: Cannot format field '%s' with '%%%s'\n", name(), fieldName, formatstr.expand()()); else error("%s: Cannot format value with '%%%s'\n", name(), formatstr.expand()()); return false; } debug("StreamCore::matchInput(%s): compare \"%s\" with \"%s\"\n", name(), inputLine.expand(consumedInput, outputLine.length())(), outputLine.expand()()); if (inputLine.length() - consumedInput < outputLine.length()) { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { error("%s: Input \"%s%s\" too short." " No match for format %%%s (\"%s\")\n", name(), inputLine.length() > 20 ? "..." : "", inputLine.expand(-20)(), formatstring, outputLine.expand()()); } return false; } if (!outputLine.startswith(inputLine(consumedInput),outputLine.length())) { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { error("%s: Input \"%s%s\" does not match" " format %%%s (\"%s\")\n", name(), inputLine.expand(consumedInput, 20)(), inputLine.length()-consumedInput > 20 ? "..." : "", formatstring, outputLine.expand()()); } return false; } consumedInput += outputLine.length(); break; } flags &= ~Separator; if (!matchValue(fmt, fieldAddress ? fieldAddress() : NULL)) { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { if (flags & ScanTried) error("%s: Input \"%s%s\" does not match format %%%s\n", name(), inputLine.expand(consumedInput, 20)(), inputLine.length()-consumedInput > 20 ? "..." : "", formatstring); else error("%s: Format %%%s has data type %s which does not match this variable.\n", name(), formatstring, StreamFormatTypeStr[fmt.type] ); } return false; } // matchValue() has already removed consumed bytes from inputBuffer fieldAddress.clear(); break; } case StreamProtocolParser::skip: // ignore next input byte consumedInput++; break; case StreamProtocolParser::whitespace: // any number of whitespace (including 0) while (isspace(inputLine[consumedInput])) consumedInput++; break; case esc: // escaped literal byte command = *commandIndex++; default: // literal byte if (consumedInput >= inputLine.length()) { int i = 0; while (commandIndex[i] >= ' ') i++; if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { error("%s: Input \"%s%s\" too short.", name(), inputLine.length() > 20 ? "..." : "", inputLine.expand(-20)()); #ifndef NO_TEMPORARY error(" No match for \"%s\"\n", StreamBuffer(commandIndex-1,i+1).expand()()); #endif } return false; } if (command != inputLine[consumedInput]) { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { int i = 0; while (commandIndex[i] >= ' ') i++; error("%s: Input \"%s%s\" mismatch after %ld byte%s\n", name(), consumedInput > 10 ? "..." : "", inputLine.expand(consumedInput > 10 ? consumedInput-10 : 0,20)(), consumedInput, consumedInput==1 ? "" : "s"); #ifndef NO_TEMPORARY error("%s: got \"%s\" where \"%s\" was expected\n", name(), inputLine.expand(consumedInput, 20)(), StreamBuffer(commandIndex-1,i+1).expand()()); #endif } return false; } consumedInput++; } } long surplus = inputLine.length()-consumedInput; if (surplus > 0 && !(flags & IgnoreExtraInput)) { if (!(flags & AsyncMode) && onMismatch[0] != in_cmd) { error("%s: %ld byte%s surplus input \"%s%s\"\n", name(), surplus, surplus==1 ? "" : "s", inputLine.expand(consumedInput, 20)(), surplus > 20 ? "..." : ""); if (consumedInput>20) error("%s: after %ld byte%s \"...%s\"\n", name(), consumedInput, consumedInput==1 ? "" : "s", inputLine.expand(consumedInput-20, 20)()); else error("%s: after %ld byte%s: \"%s\"\n", name(), consumedInput, consumedInput==1 ? "" : "s", inputLine.expand(0, consumedInput)()); } return false; } return true; } bool StreamCore:: matchSeparator() { // called before value is read, first value has Separator flag cleared // for second and next value set Separator flag if (!separator) { // empty separator matches return true; } if (!(flags & Separator)) { // before first element, don't expect separator yet flags |= Separator; return true; } long i; long j = consumedInput; for (i = 0; i < separator.length(); i++) { switch (separator[i]) { case StreamProtocolParser::skip: j++; continue; case StreamProtocolParser::whitespace: while (isspace(inputLine[j])) j++; continue; case esc: i++; default: if (separator[i] != inputLine[j]) { // no match // don't complain here, just return false return false; } j++; } } // separator successfully read consumedInput = j; return true; } long StreamCore:: scanValue(const StreamFormat& fmt, long& value) { if (fmt.type != long_format && fmt.type != enum_format) { error("%s: scanValue(long&) called with %%%c format\n", name(), fmt.conv); return -1; } flags |= ScanTried; if (!matchSeparator()) return -1; long consumed = StreamFormatConverter::find(fmt.conv)-> scanLong(fmt, inputLine(consumedInput), value); debug("StreamCore::scanValue(%s, format=%%%c, long) input=\"%s\"\n", name(), fmt.conv, inputLine.expand(consumedInput)()); if (consumed < 0) { if (fmt.flags & default_flag) { value = 0; consumed = 0; } else return -1; } if (consumed > inputLine.length()-consumedInput) return -1; debug("StreamCore::scanValue(%s) scanned %li\n", name(), value); flags |= GotValue; return consumed; } long StreamCore:: scanValue(const StreamFormat& fmt, double& value) { if (fmt.type != double_format) { error("%s: scanValue(double&) called with %%%c format\n", name(), fmt.conv); return -1; } flags |= ScanTried; if (!matchSeparator()) return -1; long consumed = StreamFormatConverter::find(fmt.conv)-> scanDouble(fmt, inputLine(consumedInput), value); debug("StreamCore::scanValue(%s, format=%%%c, double) input=\"%s\"\n", name(), fmt.conv, inputLine.expand(consumedInput, 20)()); if (consumed < 0) { if (fmt.flags & default_flag) { value = 0.0; consumed = 0; } else return -1; } if (consumed > inputLine.length()-consumedInput) return -1; debug("StreamCore::scanValue(%s) scanned %#g\n", name(), value); flags |= GotValue; return consumed; } long StreamCore:: scanValue(const StreamFormat& fmt, char* value, long maxlen) { if (fmt.type != string_format) { error("%s: scanValue(char*) called with %%%c format\n", name(), fmt.conv); return -1; } if (maxlen < 0) maxlen = 0; flags |= ScanTried; if (!matchSeparator()) return -1; long consumed = StreamFormatConverter::find(fmt.conv)-> scanString(fmt, inputLine(consumedInput), value, maxlen); debug("StreamCore::scanValue(%s, format=%%%c, char*, maxlen=%ld) input=\"%s\"\n", name(), fmt.conv, maxlen, inputLine.expand(consumedInput)()); if (consumed < 0) { if (fmt.flags & default_flag) { value[0] = 0; consumed = 0; } else return -1; } if (consumed > inputLine.length()-consumedInput) return -1; #ifndef NO_TEMPORARY debug("StreamCore::scanValue(%s) scanned \"%s\"\n", name(), StreamBuffer(value, maxlen).expand()()); #endif flags |= GotValue; return consumed; } const char* StreamCore:: getInTerminator(size_t& length) { if (inTerminatorDefined) { length = inTerminator.length(); return inTerminator(); } else { length = 0; return NULL; } } // Handle 'event' command bool StreamCore:: evalEvent() { // code layout: // eventmask timeout unsigned long eventMask = extract<unsigned long>(commandIndex); unsigned long eventTimeout = extract<unsigned long>(commandIndex); if (flags & AsyncMode && eventTimeout == 0) { if (flags & BusOwner) { busUnlock(); flags &= ~BusOwner; } } flags |= AcceptEvent; busAcceptEvent(eventMask, eventTimeout); return true; } void StreamCore:: eventCallback(StreamIoStatus status) { if (status < 0 || status > StreamIoFault) { error("StreamCore::eventCallback(%s) called with illegal StreamIoStatus %d\n", name(), status); return; } if (!(flags & AcceptEvent)) { error("StreamCore::eventCallback(%s) called unexpectedly\n", name()); return; } debug("StreamCore::eventCallback(%s, status=%s)\n", name(), StreamIoStatusStr[status]); MutexLock lock(this); flags &= ~AcceptEvent; switch (status) { case StreamIoTimeout: error("%s: No event from device\n", name()); finishProtocol(ReplyTimeout); return; case StreamIoSuccess: evalCommand(); return; default: error("%s: Event error from device: %s\n", name(), StreamIoStatusStr[status]); finishProtocol(Fault); return; } } // Handle 'wait' command bool StreamCore:: evalWait() { unsigned long waitTimeout = extract<unsigned long>(commandIndex); flags |= WaitPending; startTimer(waitTimeout); return true; } void StreamCore:: timerCallback() { MutexLock lock(this); debug ("StreamCore::timerCallback(%s)\n", name()); if (!(flags & WaitPending)) { error("StreamCore::timerCallback(%s) called unexpectedly\n", name()); return; } flags &= ~WaitPending; evalCommand(); } bool StreamCore:: evalExec() { formatOutput(); // release bus if (flags & BusOwner) { debug("StreamCore::evalExec(%s): unlocking bus\n", name()); busUnlock(); flags &= ~BusOwner; } if (!execute()) { error("%s: executing command \"%s\"\n", name(), outputLine()); return false; } return true; } void StreamCore:: execCallback(StreamIoStatus status) { switch (status) { case StreamIoSuccess: evalCommand(); return; default: error("%s: Shell command \"%s\" failed\n", name(), outputLine()); finishProtocol(Fault); return; } } bool StreamCore::execute() { error("%s: Command 'exec' not implemented on this system\n", name()); return false; } bool StreamCore::evalConnect() { unsigned long connectTimeout = extract<unsigned long>(commandIndex); if (!busConnectRequest(connectTimeout)) { error("%s: Connect not supported for this bus\n", name()); return false; } return true; } void StreamCore:: connectCallback(StreamIoStatus status) { switch (status) { case StreamIoSuccess: evalCommand(); return; default: error("%s: Connect failed\n", name()); finishProtocol(Fault); return; } } bool StreamCore::evalDisconnect() { if (!busDisconnect()) { error("%s: Cannot disconnect from this bus\n", name()); finishProtocol(Fault); return false; } return true; } void StreamCore:: disconnectCallback(StreamIoStatus status) { switch (status) { case StreamIoSuccess: evalCommand(); return; default: error("%s: Disconnect failed\n", name()); finishProtocol(Fault); return; } } #include "streamReferences"
ANJ, 17 Dec 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
