1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Breakpoint Tables
To: EPICS tech-talk <[email protected]>
Date: Thu, 16 Dec 2010 16:58:39 -0500
Title: Breakpoint Tables
I have 4 instruments that read differential pressure across V-Cone flowmeters.  The manufacturer supplied us with a 10-point calibration, which covers the desired engineering range.  These devices are not linear, and I think the right way to handle them is going to be to generate a breakpoint table for each (all 4 are sized differently).
I’m looking through the app guide, section 6.17.  Is this the accepted method to generate a breakpoint table?  Since epics was installed through a package, I don’t have the “menuConvert.dbd” file, so I’ll have to download a source archive for that.  Now, it says to copy the menuConvert.dbd file, but it doesn’t tell me where to put it.  In the source directory of the IOC application?
Section 6.13 refers to a ‘breaktable’ command.  Is that an easier way to do this?
How about a simple step-by-step description of how to generate a breakpoint table?
David
"... The Crossbow Project. There's No Defense Like a Good Offense. " - Real Genius (1985)
Don't think it exists?  Google the Air Force X-37B project.
RE: Breakpoint Tables Allison, Stephanie
Prev: RE: 24-bit DAC Tian, Yuke
Next: RE: Breakpoint Tables Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: 24-bit DAC Graham Cross
ANJ, 17 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
