Dirk,
My apologies if this wasn't clear. I saw your message just before I
left for the day.
> -----Original Message-----
> Davidsaver, Michael wrote:
> > Hi Dirk,
> > 1) Export the following before running configure. Value (yes/no)
> > depending on your environment.
The simplest thing to do is bypass the test by setting the result.
$ export ac_cv_func_setpgrp_void=yes
$ ./configure
> > 2) Comment out the test in configure.in and run 'autoreconf'.
This is another solution. You only need to do 1) or 2) not both.
> Hi Michael
> There is no configure.in, only configure.ac and configure.
I meant configure.ac ...
> There are Makefile.in and Makefile.Epics.in. Does that help?
> Dirk
> >> From: [email protected] [mailto:tech-talk-
> >> [email protected]] On Behalf Of Dirk Zimoch
> >> Sent: Monday, December 13, 2010 5:27 PM
> >> To: EPICS
> >> Subject: How to cross compile procServ?
> >> When trying to cross compile, the configure script fails with:
> >> checking whether setpgrp takes no argument... configure: error:
> cannot
> >> check setpgrp when cross compiling
> >> How can I cross compile procServ (for embedded Linux) ?
> >> Dirk
- How to cross compile procServ? Dirk Zimoch
- RE: How to cross compile procServ? Davidsaver, Michael
- Re: How to cross compile procServ? Dirk Zimoch
Re: How to cross compile procServ? Ralph Lange
Andor driver for areaDetector? Mark Rivers
<2010>
About PCAS Access Control 张玉亮
<2010>
