1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn VXI-11 Driver and VXI-11 Locking
To: William Lu <[email protected]>
Cc: [email protected]
Date: Thu, 2 Dec 2010 09:23:16 -0800
Here's the code at the beginning of the vxiCreateDeviceLink routine.  As you can see, the lockDevice parameter is always set to 0.
static BOOL vxiCreateDeviceLink(vxiPort * pvxiPort,
    char *devName,Device_Link *pDevice_Link)
    enum clnt_stat   clntStat;
    Create_LinkParms crLinkP;
    Create_LinkResp  crLinkR;
    BOOL             rtnVal = FALSE;
    asynUser         *pasynUser = pvxiPort->pasynUser;
    crLinkP.clientId = (long) pvxiPort->rpcClient;
    crLinkP.lockDevice = 0;  /* do not try to lock the device */
    crLinkP.lock_timeout = 0;/* if device is locked, forget it */
    crLinkP.device = devName;
You could try setting lockDevice to 1 and see if this gets you the effect that you want.
I don't have my VXI-11 documents handy right now to see what happens if a client disappears suddenly (from a power-fail or such) without explicitly releasing the lock.
On Dec 2, 2010, at 9:10 AM, William Lu wrote:
> Hello,
> I am using asyn records with the vxi-11 driver in a soft ioc to control the HP3458A GPIB devices through an ICS 8065 Ethernet-GPIB Controller.  I want to lock the devices using the vxi-11 locking so that the ioc has an exclusive access to the devices.  Does asyn vxi-11 driver or asyn record already provide the vxi-11 locking function for users to lock and unlock GPIB devices and if they do, how do I use them?
> Best regards,
> William Lu
> Weiwei Lu
> 757-269-7476
> [email protected]
Eric Norum
[email protected]
Re: Asyn VXI-11 Driver and VXI-11 Locking William Lu
Prev: RE: Asyn VXI-11 Driver and VXI-11 Locking Mark Rivers
Next: string array PV Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Asyn VXI-11 Driver and VXI-11 Locking William Lu
ANJ, 02 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
