1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
To: "Ritesh Sugandhi" <[email protected]>, <[email protected]>
Cc: Di Maio Franck <[email protected]>
Date: Wed, 1 Dec 2010 17:04:57 +0100
So I have just installed SL5.4 x86_64 in a virtual machine and compiled EPICS 3.14.12 and CaChannel-1.5.
Running the script gives the same results: signed number becomes unsigned.
This problem is that dbr_long_t is actually epicsUInt32. While in Py_BuildValue "l" formater converts it to 64bit long.
So in the attachment, "i" is used for dbr_long_t. That solves the problem.
I will put up a new release soon as possible.
Best,
Xiaoqiang
Sent: Wednesday, December 01, 2010 2:00 PM
To: Wang Xiaoqiang
Cc: Di Maio Franck
Subject: Re: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
Dear sir ,
thanks for your reply,
The EPICS is build with x86-64 target and the python is 64 bit.
Now, I will rebuild the CaChannel from source and check the build process and make carefully and return back to you.
Best regards,
Ritesh sugandhi
On Wed, Dec 1, 2010 at 12:47 PM, Wang Xiaoqiang <[email protected]> wrote:
Your EPICS is built with x86_64 taget? Did you build Cachannel from source? Your python is 64 bit?
Your output seems that the value is interpreted as 64 bit instead of 32bit.
Best,
Xiaoqiang
Sent: Wednesday, December 01, 2010 11:23 AM
To: Wang Xiaoqiang
Cc: Di Maio Franck; [email protected]
Dear Sir,
thanks for your quick reply. I am using CaChannel-1.5 from http://sourceforge.net/projects/igor2epics/files/CaChannel/ ? and My test system configuration is as below
RHEL 5.5. client edition x86 -64
EPICS 3.14.11
Python 2.4.3
I run your scripts and output is as below:
EPICS output is
epics> dbpf long 1234
DBR_LONG:           1234      0x4d2
epics> dbpf long 2147483647
DBR_LONG:           2147483647 0x7fffffff
epics>  dbpf long 2147483648
DBR_LONG:           -2147483648 0x80000000
epics>  dbpf long -1
DBR_LONG:           -1        0xffffffff
epics>  dbpf long -2
DBR_LONG:           -2        0xfffffffe
a.py script output is
[codac-dev@trunk ~]$ python a.py
        2010-12-01 11:09:19
long    2010-12-01 11:09:19     0
long    2010-12-01 11:13:30     1234
long    2010-12-01 11:13:44     2147483647
long    2010-12-01 11:14:07     2147483648
long    2010-12-01 11:14:21     4294967295
long    2010-12-01 11:14:45     4294967294
Any suggestion will be highly appreciated. do you think that is is 32 bit vs. 64 bit os issue?
Ritesh Sugandhi
On Wed, Dec 1, 2010 at 9:56 AM, Wang Xiaoqiang <[email protected]> wrote:
What you mean by "When ever the record attends the –ive values"?
I did a test with your snippet, into which I have added the trivial missing imports. I have attached the script and database
My test system is:
  Scientific Linux 5.1 x86
  EPICS 3.14.8
  Python 2.4.3
Here is the output. Could you run my attached script and post the output?
### IOC Log ####
slslc06> dbpf long 1234
slslc06> dbpf long 2147483647
slslc06> dbpf long 2147483648
slslc06>
#### Python Monitor ###
        2010-12-01 09:40:59
long    2010-12-01 09:40:59     0
long    2010-12-01 09:41:16     1234
long    2010-12-01 09:41:33     2147483647
Best,
Xiaoqiang
Sent: Tuesday, November 30, 2010 4:53 PM Cc: [email protected]; Wang Xiaoqiang; Di Maio Franck
Subject: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
Dear Sir,
We are using a client application develop using CaChannel-1.5 epics python interface library. The CA server is exposing a longout record which we are interested in monitoring.  When ever the record attends the –ive values. The client shows  2**32-val instead of value. while the same code works well with ao record type .
The Code is as below:
def eventMon(epics_args, user_args):
  global monPV, now
  print monPV, now, epics_args['pv_value']
def main():
  global stop, now
  try:
    monChan = CaChannel()
    monChan.search(monPV)
    monChan.pend_io()
    print now
  except CaChannelException, status:
    print ca.message(status)
  try:
    monChan.add_masked_array_event(ca.dbf_type_to_DBR_STS(monChan.field_type()), \
          None, ca.DBE_VALUE | ca.DBE_ALARM, eventMon)
  while not stop:
    now = strftime('\t%Y-%m-%d %X\t')
    ca.pend_event(0.5)
Best Regards,
Ritesh Sugandhi
Attachment: CaChannel_src.tar.gz
Description: CaChannel_src.tar.gz
Long out record PV Monitoring error in client using CaChannel-1.5 python interface Ritesh Sugandhi
RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Wang Xiaoqiang
Prev: EPID Capfast symbol Philip Taylor
Next: RE: Build EPICS Base3.14.9 on Windows Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Wang Xiaoqiang
Next: How to use BOY/OPI to produce standalone simple displays Jimmy Johnson
ANJ, 01 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
