1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Monitoring CPU temperature for small IOC
To: [email protected]
Date: Mon, 29 Nov 2010 17:20:43 -0800
Hello all
I have a Linux based IOC running on a dedicated small hardware platform (Atom CPU in Mini-ITX form factor) We would like this to have no moving parts, which means monitoring the CPU state becomes critical on hot summer days. Is there support for monitoring CPU temperatures using the /proc/acpi service? It seems like this would be something that devIocStats could provide, but perhaps it is too system dependent.
Is there an easy way to collect information from the IOC host system and place it into PVs? Regular reading of /proc/acpi/thermal_zone/THRM will give an updated CPU core temperature, but it is not clear to me how to place this into a PV.
Thanks in advance.
David
David Morris                              TRIUMF
Systems Designer                          4004 Wesbrook Mall
Ph  604-222-7450                          Vancouver, B.C.
Fax 604-222-7307                          V6T 2A3, Canada
RE: Monitoring CPU temperature for small IOC Allison, Stephanie
Prev: Re: Testing UIs against real databases using simulation mode Andrew Johnson
Next: RE: Monitoring CPU temperature for small IOC Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: New StreamDevice version Dirk Zimoch
ANJ, 06 Dec 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
