1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION
To: EPICS Tech Talk <[email protected]>
Date: Thu, 25 Nov 2010 11:33:31 +0100
I'm testing the 3.14.12 release!
Here is the diff of config that I've changed:
--- ../base-3.14.12.org/configure/CONFIG_SITE 2010-11-24 21:54:36.000000000 +0100
+++ ../base-3.14.12/configure/CONFIG_SITE 2010-11-25 10:20:52.809374249 +0100
@@ -169,6 +169,9 @@
# define INSTALL_LOCATION here
#INSTALL_LOCATION=<fullpathname>
+# Hinko, Thu Nov 25 08:35:13 CET 2010
+INSTALL_LOCATION=$(TOP)/../install
 # Use POSIX thread priority scheduling (YES or NO)
 USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO
diff -urN -x 'O.*' ../base-3.14.12.org/configure/RELEASE ../base-3.14.12/configure/RELEASE
--- ../base-3.14.12.org/configure/RELEASE 2010-11-24 21:54:36.000000000 +0100
+++ ../base-3.14.12/configure/RELEASE 2010-11-25 10:47:01.000000000 +0100
@@ -19,3 +19,11 @@
# RELEASE.Common.$(T_A)
# RELEASE.$(EPICS_HOST_ARCH).$(T_A)
+INSTALL_LOCATION_EXTENSIONS=$(TOP)/../../install
+# If EPICS_BASE is set here base compilation fails..
+#EPICS_BASE=$(TOP)/../../install
+EPICS_EXTENSIONS=$(TOP)
Example IOC was created with:
$ makeBaseApp.pl -t example evgen
$ makeBaseApp.pl -i -t example evgen
$ make
make -C ./configure install
make[1]: Entering directory `/home/hinko/work/epics/evgen/configure'
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/home/hinko/work/epics/evgen/configure/O.linux-x86'
perl /home/hinko/work/epics/install/bin/linux-x86/convertRelease.pl checkRelease
EPICS/Release.pm: Circular definition of macro TOP
make[2]: *** [checkRelease] Error 2
make[2]: Leaving directory `/home/hinko/work/epics/evgen/configure/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/home/hinko/work/epics/evgen/configure'
make: *** [configure.install] Error 2
Best regards, Hinko
-- Hinko Kocevar Technical support software engineer Instrumentation Technologies d.d. Velika pot 22, SI-5250 Solkan - Slovenia T:+386 5 3352600, F:+386 5 3352601 mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Andrew Johnson
Prev: RE: EPICS Base 3.14.12 released. Jim Chen
Next: Testing UIs against real databases using simulation mode Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Base 3.14.12 released. Korhonen Timo
Next: Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Andrew Johnson
ANJ, 29 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
