One major problem is that generic code can't know whether it is safe to re-run a put that fails for this reason or not. If there is significant I/O or other processing in the chain of records that leads up to the record that's busy then it might *not* be safe to repeat the put operation. It doesn't matter where we propose to put the retry code, the same issue arises; only the person designing the overall system can work out what the correct response is. +1 Returning a warning seems like the right compromise between the current behavior of returning OK (not even letting the client know that the situation occurred) and queueing/rerunning the process chain (which might be unsafe and/or unintended). Providing the client with as much information as possible, without making assumptions of its intentions. This is definitely a 3.15 (or later) change by the way, and there is already a major modification to the putNotify code in the queue in front of this so I'm not going to be able to apply Ben's changes for some time, giving us a chance to work out the consequences properly. For the sake of people using the sequencer under 3.14, we could make it a "known problem" and provide a patch on the EPICS web site. ~Ralph
ANJ, 24 Nov 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
