1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: subrecord INPx
To: Hinko Kocevar <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 24 Nov 2010 08:42:13 -0800
Please provide a full (level 5) dbpr output of both records.  Also, please provide the version of epics base and the OS of the IOC.
Thank you,
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Hinko Kocevar
> Sent: Wednesday, November 24, 2010 6:50 AM
> To: EPICS Tech Talk
> Subject: subrecord INPx
> Hi,
> I'm poking around the example IOC I've created with:
> $ makeBaseApp.pl -t example app1
> $ makeBaseApp.pl -i -t example app1
> Example runs fine and records are behaving as expected, but..
> I tried to experiment with subRecord, but the mySubProcess routine does
> not seem to get values on INPx fields if they are not constants. I've
> added following line to get INPA value inside the C function:
> static long mySubProcess(subRecord *precord)
>      if (mySubDebug)
>          printf("Record %s called mySubProcess(%p)\n",
>                 precord->name, (void*) precord);
>      printf("precord->a %lf\n", precord->a);
>      printf("precord->b %lf\n", precord->b);
>      return 0;
> Example:
> record(sub,"$(user):subExample")
>      field(INAM,"mySubInit")
>      field(SNAM,"mySubProcess")
>      field(INPA, "$(user):subInc")
>      field(INPB, "123")
> record(calc, "$(user):subInc") {
>    field(SCAN, "1 second")
>    field(VAL, "0")
>    field(CALC, "(A+1)")
>    field(INPA, "$(user):subInc.VAL NPP")
> Output from IOC:
> Record hinkoHost:subcall called mySubProcess(0x9205998)
> precord->a 0.000000
> precord->b 123.000000
> precord->a 0.000000
> precord->a 0.000000
> At the same time, if I monitor the $(user):subInc:
> camonitor hinkoHost:subInc
> hinkoHost:subInc               2010-11-24 15:45:57.346136 14
> hinkoHost:subInc               2010-11-24 15:45:58.346438 15
> hinkoHost:subInc               2010-11-24 15:45:59.346628 16
> What am I missing?
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
RE: subrecord INPx Hinko Kocevar
Prev: RE: ca_put_callback once again Jeff Hill
Next: Re: MAXv issue Jens . Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: subrecord INPx Hinko Kocevar
Next: RE: subrecord INPx Hinko Kocevar
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
