1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: subrecord INPx
To: <[email protected]>
Date: Wed, 24 Nov 2010 13:33:53 -0300
Hi Hinko,
its' not clear in your example how you produced a console trace for your sub record, there is nothing obvious in your db example to make it process.
try add a FLNK, should work
> record(calc, "$(user):subInc") {
> field(SCAN, "1 second")
> field(VAL, "0")
> field(CALC, "(A+1)")
> field(INPA, "$(user):subInc.VAL NPP")
  field(FLNK, "$(user):subExample")
Matthieu
On 11/24/10 11:49, Hinko Kocevar wrote:
I'm poking around the example IOC I've created with:
$ makeBaseApp.pl -t example app1
$ makeBaseApp.pl -i -t example app1
Example runs fine and records are behaving as expected, but..
I tried to experiment with subRecord, but the mySubProcess routine does
not seem to get values on INPx fields if they are not constants. I've
added following line to get INPA value inside the C function:
static long mySubProcess(subRecord *precord)
if (mySubDebug)
printf("Record %s called mySubProcess(%p)\n",
precord->name, (void*) precord);
printf("precord->a %lf\n", precord->a);
printf("precord->b %lf\n", precord->b);
return 0;
Example:
record(sub,"$(user):subExample")
field(INAM,"mySubInit")
field(SNAM,"mySubProcess")
field(INPA, "$(user):subInc")
field(INPB, "123")
field(VAL, "0")
Output from IOC:
Record hinkoHost:subcall called mySubProcess(0x9205998)
precord->a 0.000000
precord->b 123.000000
precord->a 0.000000
precord->a 0.000000
At the same time, if I monitor the $(user):subInc: camonitor hinkoHost:subInc hinkoHost:subInc 2010-11-24 15:45:57.346136 14 hinkoHost:subInc 2010-11-24 15:45:58.346438 15 hinkoHost:subInc 2010-11-24 15:45:59.346628 16
What am I missing?
Best regards,
Hinko
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
RE: subrecord INPx Hinko Kocevar
Prev: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Next: RE: ca_put_callback once again Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: subrecord INPx Hinko Kocevar
Next: RE: subrecord INPx Hinko Kocevar
ANJ, 24 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
