Hi Tim, Andrew, Jeff
thanks for all your comments.
I don't think it is necessary or even a good idea to try to avoid all
collisions in the database. For the moment I would be happy just to be
notified if parts of the process network is busy and so doesn't get
processed as a result of my put.
I went ahead and took a look at the code. It turns out that this can be
achieved with a minimal effort (a 4 lines change to the code in
src/db/dbPutNotify.[ch]). And indeed, this takes care that the CA server
sends back an error. My test now says:
> time caput pvPutAsync1 1 &; sleep 1; time caput -c -w5 pvPutAsync2 1
1
[1] 19959
Old : pvPutAsync1 Low
New : pvPutAsync1 High
caput pvPutAsync1 1 0.01s user 0.00s system 20% cpu 0.038 total
[1] + 19959 done time caput pvPutAsync1 1
Old : pvPutAsync2 Low
Error occured writing data.
caput -c -w5 pvPutAsync2 1 0.00s user 0.01s system 22% cpu 0.035 total
However, I though it would be nicer if the server could send a more specific
error code, instead of the generic "put failed", the more so because the put
itself did in fact not fail, only the processing chain gets stopped short.
This is also easy to do, it needs a single 4 lines change in
src/rsrv/camessage.c. Plus the two lines for the new error code -- actually
just a warning, as the definition is:
#define ECA_PUTCBNOTCMPL DEFMSG(CA_K_WARNING, 61)
Then I saw that caput does not retrieve the error message from the CA
library, so I added this too.
All in all:
> darcs whatsnew -s
M ./src/ca/access.cpp -1 +2
M ./src/ca/caerr.h +1
M ./src/catools/caput.c -1 +2
M ./src/db/dbNotify.c -1 +4
M ./src/db/dbNotify.h -1 +2
M ./src/rsrv/camessage.c -1 +4
A patch against base-3.14.12-rc1 is attached.
My test now does what it's supposed to do:
> time ./bin/linux-x86/caput pvPutAsync1 1 &; sleep 1; time ./bin/linux-
x86/caput -c -w5 pvPutAsync2 1
[1] 29635
./bin/linux-x86/caput pvPutAsync1 1 0.01s user 0.00s system 24% cpu 0.032
total
[1] + 29635 done time ./bin/linux-x86/caput pvPutAsync1 1
Error occured writing data:Put callback processing incomplete
./bin/linux-x86/caput -c -w5 pvPutAsync2 1 0.00s user 0.00s system 12% cpu
0.032 total
On Tuesday, November 23, 2010, you wrote:
> > From: "Ben Franksen" <[email protected]>
> > To: [email protected]
> > Sent: Monday, November 22, 2010 9:59:04 PM
> > Subject: Re: ca_put_callback once again
> > Hi Andrew
> > We have two separate issues here.
> > (1) The bo record. I was aware of the fact that the bo record does not
> > remain active during its HIGH time. Maybe I should have explained the
> > idea behind the test db file a bit more, but I added the test setup as
> > an afterthought and the mail was already long enough. I am using the
> > bo
> > record's HIGH field only so that I can see a change in the value with
> > a
> > camonitor in another window. The actual asynchronous processing is
> > done
> > by the seq record which has a longer delay for exactly this reason. I
> > could as well have used a longout for the two "front-end" records and
> > the result would have surprised me as much.
> > I am not proposing to change the bo behaviour.
> > (2) The putNotify behaviour. I admit that I did not read the manual
> > carefully enough. You cite the ADG:
> > > 6. In general a set of records may be processed as a result of a
> > > single dbPutNotify. If a record in the set is found to be active,
> > > either because PACT is true or because a putNotify already owns the
> > > record, then that record is not made part of the set of records that
> > > must complete before the putNotify request completes.
> > This should have led me to expect the behaviour I see.
> > > Your second caput is completing immediately because its bo record
> > > tries to process the OUT link but finds the seq.PACT=TRUE, so it
> > > gives up and tells putNotify that everything it started has
> > > finished.
> > Agreed, but this is exactly the problem I complained about.
> > It tells me that an operation successfully completed, when in fact it
> > did *not* succeed. The bo was supposed to start more than its own
> > processing, namely processing of the seq record, and this id not
> > happen.
> I think there's a legitimate question about what should happen in this
> case, and I hope to get a better view of it by thinking of similar cases:
> Suppose the second dbput to the seq record had resulted from a loop in
> the database, rather than from a second ca_put_callback. Normal database
> processing rules would have called for loop processing to stop when it
> tried to process a record already processing as the result of a dbput.
> I think neither of us would regard this as an error -- I have databases,
> in fact, that rely on this behavior to function correctly. But this
> case would have looked almost exactly the same as yours to the database
> processing routines: the only difference is that the second dbput would
> have propagated the /original/ put_callback to the seq record for a
> second time, instead of propagating a /new/ put_callback. (Thus, one
> conceivable solution might involve named putNotifys.)
> Another similar case: Suppose you had executed the bo records with
> ordinary ca_puts, instead of ca_put_callbacks. You would have gotten
> exactly the same database-processing result, which is good -- ca_put
> should achieve the same result as ca_put_callback. But, with caput,
> there's no possibility of signaling the collision as an error, because
> the execution is not traced, so when a collision occurs no code knows
> who started it. (The nice thing about ca_put_callback is that it gives
> the caller has a way to avoid a database-processing collision, as long
> as nobody else is trying to process the database at the same time.)
> One possible view of this is that the problem is in the collision, not
> in either the database-processing rules or in ca_put_callback. It's
> unfortunate that the user can rarely be expected to know whether or
> not two puts are going to the same lock set and might collide, but I
> can't think of a way out that doesn't involve a deep redesign.
> > It should be possible to record such a failure and return it
> > to
> > the requester. Even better, the CA server could detect the failure and
> > wait until the record in question is no longer busy. It already does
> > so
> > under certain circumstances, namely if I target the same front-end
> > record from the same client: in this case the second call waits for
> > the
> > first fo finish, i.e. the CA server queues the second request.
> > (Unfortunately I cannot as easily demonstrate this because caput does
> > not allow to group several asynchronous put operations in one
> > command.)
> > If I target a different record (even from the same client), this
> > queuing
> > does not happen. This is inconsistent. I think that the queueing
> > should
> > ideally always happen for ca_put_callback as long as any record in teh
> > chain is busy. Failing that, or if the wait times out, at least an
> > error should be sent back.
> > Considering the effort that went into the implementation of the
> > putNotify feature it seems a shame that it cannot be used for what it
> > was designed, at least not reliably.
> > Since I don't expect this will be fixed any time soon, I will warn
> > users
> > of the sequencer that using pvPut(var,SYNC) is inherently unreliable.
> > Instead completion should be detected by other means, such as reading
> > back a status bit from the hardware.
> We tried that. For years I tried different ways to make that work. It
> was awful. put_callback made a *huge* improvement in the speed,
> robustness, and flexibility of scans. Inmportantly, it allows clients
> to scan a PV without knowing which other PV to read to detect
> completion.
> I agree that put_callback has problems with collisions, and I don't mean
> to minimize the problems. But I think it's so much better than the
> achievable alternatives that I would not suggest SNL developers avoid it.
> > Cheers
> > Ben
Helmholtz-Zentrum Berlin fÃr Materialien und Energie GmbH
Hahn-Meitner-Platz 1, 14109 Berlin
Vorsitzende des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
Stellvertretende Vorsitzende: Dr. Beatrix Vierkorn-Rudolph GeschÃftsfÃhrer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Sitz der Gesellschaft: Berlin Handelsregister: AG Charlottenburg, 89 HRB 5583
Disclaimer automatically attached by the E-Mail Security Appliance
mail0.bessy.de 11/24/10 at Helmholtz-Zentrum Berlin GmbH.
Wed Nov 24 11:35:13 CET 2010 [email protected]
* ca_put_callback now reports incomplete processing
The goal here is that CA clients issuing a ca_put_callback will be
notified if the processing chain gets stopped short because one of the
records to be processed is active or blocked buy another putNotify.
The putNotify callback gets a new status value, the CA server gets
a new error code.
diff -rN -u old-base-3.14.12.0.1/src/ca/access.cpp new-base-3.14.12.0.1/src/ca/access.cpp
--- old-base-3.14.12.0.1/src/ca/access.cpp 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/ca/access.cpp 2010-11-24 11:41:33.000000000 +0100
@@ -122,7 +122,8 @@
"Client's protocol revision does not support transfers exceeding 16k bytes",
"Virtual circuit connection sequence aborted",
-"Virtual circuit unresponsive"
+"Virtual circuit unresponsive",
+"Put callback processing incomplete",
static epicsThreadOnceId caClientContextIdOnce = EPICS_THREAD_ONCE_INIT;
diff -rN -u old-base-3.14.12.0.1/src/ca/caerr.h new-base-3.14.12.0.1/src/ca/caerr.h
--- old-base-3.14.12.0.1/src/ca/caerr.h 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/ca/caerr.h 2010-11-24 11:41:33.000000000 +0100
@@ -144,6 +144,7 @@
#define ECA_16KARRAYCLIENT DEFMSG(CA_K_WARNING, 58)
#define ECA_CONNSEQTMO DEFMSG(CA_K_WARNING, 59)
#define ECA_UNRESPTMO DEFMSG(CA_K_WARNING, 60)
+#define ECA_PUTCBNOTCMPL DEFMSG(CA_K_WARNING, 61)
#ifdef __cplusplus
extern "C" {
diff -rN -u old-base-3.14.12.0.1/src/catools/caput.c new-base-3.14.12.0.1/src/catools/caput.c
--- old-base-3.14.12.0.1/src/catools/caput.c 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/catools/caput.c 2010-11-24 11:41:33.000000000 +0100
@@ -543,7 +543,8 @@
if (result != ECA_NORMAL) {
- fprintf(stderr, "Error occured writing data.\n");
+ fprintf(stderr, "Error occured writing data:%s\n",
+ ca_message(result));
return 1;
diff -rN -u old-base-3.14.12.0.1/src/db/dbNotify.c new-base-3.14.12.0.1/src/db/dbNotify.c
--- old-base-3.14.12.0.1/src/db/dbNotify.c 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/db/dbNotify.c 2010-11-24 11:41:33.000000000 +0100
@@ -432,7 +432,10 @@
putNotify *ppn = pfrom->ppn;
putNotifyPvt *pputNotifyPvt;
- if(pto->pact) return; /*if active it will not be processed*/
+ if(pto->pact) {
+ ppn->status = putNotifyNotComplete;
+ return; /*if active it will not be processed*/
epicsMutexMustLock(pnotifyGlobal->lock);
if(!pto->ppnr) {/* make sure record has a putNotifyRecord*/
pto->ppnr = dbCalloc(1,sizeof(putNotifyRecord));
diff -rN -u old-base-3.14.12.0.1/src/db/dbNotify.h new-base-3.14.12.0.1/src/db/dbNotify.h
--- old-base-3.14.12.0.1/src/db/dbNotify.h 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/db/dbNotify.h 2010-11-24 11:41:33.000000000 +0100
@@ -33,7 +33,8 @@
putNotifyOK,
putNotifyCanceled,
putNotifyError,
- putNotifyPutDisabled
+ putNotifyPutDisabled,
+ putNotifyNotComplete
}putNotifyStatus;
typedef struct putNotify{
diff -rN -u old-base-3.14.12.0.1/src/rsrv/camessage.c new-base-3.14.12.0.1/src/rsrv/camessage.c
--- old-base-3.14.12.0.1/src/rsrv/camessage.c 2010-11-24 11:41:32.000000000 +0100
+++ new-base-3.14.12.0.1/src/rsrv/camessage.c 2010-11-24 11:41:33.000000000 +0100
@@ -1460,7 +1460,10 @@
* Map from DB status to CA status
- if ( ppnb->dbPutNotify.status != putNotifyOK ) {
+ if ( ppnb->dbPutNotify.status == putNotifyNotComplete ) {
+ status = ECA_PUTCBNOTCMPL;
+ else if ( ppnb->dbPutNotify.status != putNotifyOK ) {
status = ECA_PUTFAIL;
else{
- RE: ca_put_callback once again Jeff Hill
- Re: ca_put_callback once again Tim Mooney
sncseq compiling error 王锐萍
Re: sncseq compiling error Benjamin Franksen
<2010>
<2010>
