Hello tech-talk,
There is a related message on the subject of get_precision by Bernd Schoeneburg here (Oct 2009):
http://www.aps.anl.gov/epics/tech-talk/2009/msg01525.php
There was also another email recently that had a comment about precision (from Michael Abbott) that caught my interest but may not be related.
In our upgrade from 3.14.8.2 to 3.14.11, we discovered some of our clients are showing the wrong precision for calc records. In fact, the output of caget and camonitor when using the "-s" option is different in precision for calc and calcout records. For example:
b117-pc12:~>caget SPEAR:Energy.PREC
SPEAR:Energy.PREC 3
b117-pc12:~>caget -s SPEAR:Energy
SPEAR:Energy 3.000
b117-pc12:~>camonitor -s SPEAR:Energy
SPEAR:Energy 2010-11-23 13:56:07.677011 3.000004
(SPEAR:Energy is a calc record, dbpr is at the end of this email).
ai, ao, sel, compress, waveform, dfanout, sub records are all OK. Just calc's and calcout's are wrong.
Most of our standard epics extensions are like caget and get the proper precision when getting a value as a string.
In the calc and calcout records (in 3.14.11 and 3.14.12 too), get_precision still has the bug that Bernd identified in his email. The existing code is like this:
static long get_precision(DBADDR *paddr, long *pprecision)
calcRecord *prec = (calcRecord *)paddr->precord;
if (paddr->pfield == (void *)&prec->val) {
*pprecision = prec->prec;
} else {
recGblGetPrec(paddr, pprecision);
return 0;
The first bug is that pprecision must be initialized before calling recGblGetPrec. But what I've also discovered is that this line does not always work correctly depending on what channel access call is used - ca_create_subscription or ca_array_get_callback (which makes no sense):
get_precision for other record types check the field index instead so when I correct calc and calcout like this:
int fieldIndex = dbGetFieldIndex(paddr);
if (fieldIndex != calcRecordVAL)
return 0;
All works OK.
BTW - the help for camonitor shows this text:
-s: Get value as string (may honour server-side precision)
When won't server-side precision be honored/honoured?
I will report a bug via launchpad but thought perhaps others may be interested. Thank you,
Stephanie Allison
[email protected]
IOC running on Linux RHEL4-32/EPICS 3.14.11:
epics> dbpr("SPEAR:Energy",5)
A: 587.691345214844 ACKS: INVALID ACKT: YES ADEL: 0
ALST: 3.00000227269902 ASG: ASP: (nil)
B: 0 BKPT: 00 C: 0
CALC: A<0?0:((A*3)/587.6909) D: 0 DESC: SPEAR Energy
DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
DPVT: (nil) DSET: (nil) DTYP: <nil> E: 0
EGU: GeV EVNT: 0 F: 0 FLNK:CONSTANT 0
G: 0 H: 0 HHSV: NO_ALARM HIGH: 0
HIHI: 0 HOPR: 0 HSV: NO_ALARM HYST: 0
I: 0 INPA:DB_LINK MS1-BD:Curr.VAL NPP MS INPB:CONSTANT
INPC:CONSTANT INPD:CONSTANT INPE:CONSTANT INPF:CONSTANT
INPG:CONSTANT INPH:CONSTANT INPI:CONSTANT INPJ:CONSTANT
INPK:CONSTANT INPL:CONSTANT J: 0 K: 0
L: 0 LA: 587.691345214844
LALM: 3.00000227269902 LB: 0 LC: 0
LCNT: 0 LD: 0 LE: 0 LF: 0
LG: 0 LH: 0 LI: 0 LJ: 0
LK: 0 LL: 0 LLSV: NO_ALARM LOLO: 0
LOPR: 0 LOW: 0 LSET: 0x8a5d450 LSV: NO_ALARM
MDEL: 0 MLIS: e8 71 bc 08 58 d6 c3 08 0e 00 00 00
MLOK: b8 6a a2 08 MLST: 3.00000227269902 NAME: SPEAR:Energy
NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0
PINI: NO PPN: (nil) PPNR: 0x8b8e018 PREC: 3
PRIO: LOW PROC: 0 PUTF: 0 RDES: 0x88188a8
RPCL: 03 01 00 00 00 00 00 00 00 00 47 4c 01 00 00 00 00 00 00 00
RPRO: 0 RSET: 0x817e9c0 SCAN: Passive SDIS:CONSTANT
SEVR: NO_ALARM SPVT: (nil) STAT: NO_ALARM
TIME: 2010-11-23 14:07:10.996273000 TPRO: 0 TSE: 0
TSEL:CONSTANT UDF: 0 VAL: 3.00000227269902
- Re: Incorrect get_precision Ralph Lange
Re: ca_put_callback once again Tim Mooney
<2010>
RE: fast epid Mark Rivers
<2010>
