1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cross-compilation missing library
Cc: [email protected]
Date: Fri, 19 Nov 2010 15:04:13 -0800
> > We agree that epics itself should be build with arm arch to build arm iocs.
> > So I need to have the epics arm libs on my system before compiling the
> > iocs. Well, for epics that's easy since we build from source and epics has
> > only 'standard_c_lib' dependencies. Now what about non-standard libs (like
> > flex ;), which I could yum/apt-get. Do I need to compile them from source
> > against the crosstool? And what about the dependencies of the dependencies
> You're outside my range of expertise there.  If you're using a Debian-derived
> Linux and tool-chain or similar that provides those libs pre-built for ARM
> then you should be able to fetch and install them using the standard tools,
> but that's outside the realm of the EPICS developers.
It turns out qemu-arm is used just for that.
Bing or google it and you will see how to build an arm virtual machine (in user space) on
an intel cpu. FYI.
Emmanuel
Cross-compilation missing library emmanuel_mayssat
Re: Cross-compilation missing library Andrew Johnson
Re: Cross-compilation missing library emmanuel_mayssat
Prev: ChannelFinder Web Service 1.0.0 (beta) released Ralph Lange
Next: ca_put_callback once again Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Cross-compilation missing library Andrew Johnson
Next: How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
ANJ, 21 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
