1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MCA (Matlab Channel Access) new version
To: Korhonen Timo <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 17 Nov 2010 08:25:42 -0800
When I build for octave with EPICS_HOST_ARCH=linux-x86_64
(Linux apex4.als 2.6.18-194.17.4.el5xen #1 SMP Mon Oct 25 16:36:31 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux)
I get some warnings -- reaching the end of a non-void function sounds like it might be a real issue. I have no idea what the final warning is about.
mkoctfile --mex -DmexAtExit=atexit -v -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DEPICS_DLL_NO -L/usr/local/epics/R3.14.12/base/lib/linux-x86_64 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -o O.linux-x86_64/mca.mex
g++ -c -DH5_USE_16_API -fPIC -I/usr/include/octave-3.0.5 -I/usr/include/octave-3.0.5/octave -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO mca.cpp -o mca.o
mca.cpp: In function ‘void mexFunction(int, mxArray**, int, const mxArray**)’:
mca.cpp:429: warning: unused variable ‘NoStrings’
mca.cpp:430: warning: unused variable ‘mymxArray’
queue.h: In member function ‘T Queue<T>::Dequeue() [with T = int]’:
queue.h:176: warning: control reaches end of non-void function
g++ -c -DH5_USE_16_API -fPIC -I/usr/include/octave-3.0.5 -I/usr/include/octave-3.0.5/octave -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO MCAError.cpp -o MCAError.o
g++ -c -DH5_USE_16_API -fPIC -I/usr/include/octave-3.0.5 -I/usr/include/octave-3.0.5/octave -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Linux -DmexAtExit=atexit -DEPICS_DLL_NO Channel.cpp -o Channel.o
Channel.h: In constructor ‘Channel::Channel(const ChannelAccess*, const char*)’:
Channel.h:179: warning: ‘Channel::last_put_ok’ will be initialized after
Channel.h:171: warning:   ‘dbr_gr_enum Channel::EnumStrings’
Channel.cpp:19: warning:   when initialized here
When I build for octave with EPICS_HOST_ARCH=darwin-x86 I get different warnings.  These sound a little more benign...
mkdir O.darwin-x86
mkoctfile --mex -DmexAtExit=atexit -v -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Darwin -DEPICS_DLL_NO -L/usr/local/epics/R3.14.12/base/lib/darwin-x86 -ldbStaticHost -lCom -lca mca.cpp MCAError.cpp Channel.cpp -o O.darwin-x86/mca.mex
/sw/bin/g++-4 -c -I/usr/local/include -D_REENTRANT -I/sw/include -fPIC -I/usr/local/include/octave-3.2.4 -I/usr/local/include/octave-3.2.4/octave -I/usr/local/include -mieee-fp -I/sw/include/freetype2 -I/sw/include -g -O2 -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Darwin -DmexAtExit=atexit -DEPICS_DLL_NO mca.cpp -o mca.o
In file included from mca.cpp:24:
Channel.h: In member function 'char* Channel::GetHostName() const':
Channel.h:29: warning: deprecated conversion from string constant to 'char*'
/sw/bin/g++-4 -c -I/usr/local/include -D_REENTRANT -I/sw/include -fPIC -I/usr/local/include/octave-3.2.4 -I/usr/local/include/octave-3.2.4/octave -I/usr/local/include -mieee-fp -I/sw/include/freetype2 -I/sw/include -g -O2 -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Darwin -DmexAtExit=atexit -DEPICS_DLL_NO MCAError.cpp -o MCAError.o
/sw/bin/g++-4 -c -I/usr/local/include -D_REENTRANT -I/sw/include -fPIC -I/usr/local/include/octave-3.2.4 -I/usr/local/include/octave-3.2.4/octave -I/usr/local/include -mieee-fp -I/sw/include/freetype2 -I/sw/include -g -O2 -I. -I/usr/local/epics/R3.14.12/base/include -I/usr/local/epics/R3.14.12/base/include/os/Darwin -DmexAtExit=atexit -DEPICS_DLL_NO Channel.cpp -o Channel.o
In file included from Channel.cpp:4:
On Nov 17, 2010, at 3:08 AM, Korhonen Timo wrote:
> Dear all,
> the enhancements to mca (Matlab Channel Access) that I announced in the last EPICS meeting are now
> available (except the GUI objects - those are not really part of the mca. They will follow later - if there
> is interest..)
> After consulting with Kay Kasemir we decided to put the code into SourceForge (sorry APS folks,
> I know you have problems with it) epics-applications project:
> https://sourceforge.net/projects/epics/
> The code is in CVS:/extensions/mca
> It has been in use here at PSI for a while (apart from one small change in egu handling) on our
> Scientific Linux 5 machines and I am not aware of any open issues.
> Please take a look at the code and see if it works on other platforms and with Octave.
> Do not hesitate to point out problems - I am not very experienced in matlab interface API
> and my C++ skills also need some brushing up...
> The main changes are listed in the release note (for version 4.2)
> cheers,
> Timo
> Timo Korhonen  PSI (Paul Scherrer Institut, http://www.psi.ch)               CH-5232 Villigen PSI               tel + 41- 56 3103262  fax + 41 - 56 310 5090 e-mail:	       [email protected]
Eric Norum
[email protected]
Re: MCA (Matlab Channel Access) new version Korhonen Timo
Prev: Re: MCA (Matlab Channel Access) new version Andrew Johnson
Next: Re: How to shutdown/restart a soft-ioc from a (watchdog) record Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: MCA (Matlab Channel Access) new version Korhonen Timo
ANJ, 18 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
