1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cross-compilation missing library
Cc: [email protected]
Date: Tue, 16 Nov 2010 15:35:18 -0800
On 17:52 Tue 16 Nov     , Andrew Johnson wrote:
> On Tuesday 16 November 2010 16:04:48 [email protected] wrote:
> > Ok, Andrew, I will try your solution.
> > Now assuming that I need flex... how would I do that?
> You don't.
Are you saying:
(1) I don't need flex
or (2) that I should never install additional libraries in my crosstool?
My question is now just about working with crosstool chain, and not about flex in
particular.
We agree that epics itself should be build with arm arch to build arm iocs.
So I need to have the epics arm libs on my system before compiling the iocs.
Well, for epics that's easy since we build from source and epics has only
'standard_c_lib' dependencies. Now what about non-standard libs (like flex ;), which I
could yum/apt-get. Do I need to compile them from source against the crosstool?
And what about the dependencies of the dependencies ?
I wish you had said that
chroot .../toolchain_dir
apt-get/yum install <my_lib>
could do the trick...
For example, how to compile medm/edm for arm since I need the correct arch GUI libs?
Could a dynamic build save the day? Just dreaming ...
Emmanuel
Re: Cross-compilation missing library Andrew Johnson
Cross-compilation missing library emmanuel_mayssat
Re: Cross-compilation missing library emmanuel_mayssat
Prev: Re: the hex instruction convert Dirk Zimoch
Next: Re: Cross-compilation missing library Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Cross-compilation missing library Andrew Johnson
ANJ, 16 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
