1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: the hex instruction convert
To: [email protected]
Cc: [email protected]
Date: Wed, 17 Nov 2010 00:04:22 +0100
out “\x01\x01\x00\x01%.4r%<sum>”; or out $1 0x01 $2 $3 “%.4r%<sum>”;
%4r would sign extend 1 byte data to 4 bytes output.
%.4r prints 4 byte data.
The documentation is wrong here. I will fix that.
Dirk
[email protected] wrote:
I think the stream device protocol converters %r and %<sum> will do what you want :
out “\x01\x01\x00\x01%4r%<sum>”;
But you would probably want to pass the address information as variables :
out $1 0x01 $2 $3 “%4r%<sum>”;
*From:* [email protected] [mailto:[email protected]] *On Behalf Of *Damek Yahto
*Sent:* 16 November 2010 03:06
*To:* [email protected]
*Subject:* the hex instruction convert
HI Tech-talk,I am trying to build an IOC to communicate with serial devices through the serial to Ethernet Device Server.
The serial device supports the streams of hex format.
The binary command format when using RS232 or RS485 is as follows:
Bytes    Meaning
1        Module address
1        Command number
1        Type number
1        Motor or Bank number
4        Value (MSB first!)
1        Checksum
total: 9 bytes
the checksum is calculated by adding up all bytes (including the module address byte) using
8-bit addition. Here is the examples to show how to do this:
in C:
unsigned char i, Checksum;
unsigned char Command[9];
    //Set the “Command” array to the desired command
    Checksum = Command[0];
    for(i=1; i<8; i++)
        Checksum+=Command[i];
    Command[8]=Checksum; //insert checksum as last byte of the command
     //Now, send it to the module
I want to control the motor to rotate right through the serial device.
Instruction:
Rotate right, motor #1, velocity = 350
Binary:
Byte Index 0 1 2 3 4 5 6 7 8
Function Target- Instruction Type Motor/ Operand Operand Operand Operand Checksum
address Number Bank Byte3 Byte2 Byte1 Byte0
Value (hex) 0x01 0x01 0x00 0x01 0x00 0x00 0x01 0x5e 0x62
By writing streamDevice protocol file(out'\x01\x01\x00\x01\x00\x00\x01\x5e\x62';),motor will rotate. Using "EDM" or "caput" to
input the variable,where do I do my processing (like calculating the Checksum and convert the velocity to four bytes long)? where
write my own parsing code in C?having other approaches. Could you give any example?
Yahto Dam
2010.11.16
-- Scanned by iCritical.
the hex instruction convert Damek Yahto
RE: the hex instruction convert peter.owens
Prev: Re: Cross-compilation missing library Andrew Johnson
Next: Re: Cross-compilation missing library emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: the hex instruction convert peter.owens
Next: Cross-compilation missing library emmanuel_mayssat
ANJ, 16 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
