Dirk,
I'll add that to the asyn known problems. Does VS 10 have the same problem with the header file as VS Express 2008 that Anthony Owen discovered?
Sent: Tue 11/16/2010 4:00 AM
To: Eric Norum
Cc: EPICS Techtalk; Mark Rivers
Subject: Re: asyn driver on Windows XP
Compiling asyn with make USR_CFLAGS=/D_WIN32_WINNT=0x0500 solves the
problem. I have no idea why _WIN32_WINNT is set to something >= 0x0600
(=Vista).
Dirk
Eric Norum wrote:
> The conditionals in drvAsynIPPort.c were supposed to handle this case:
> #if defined(__rtems__)
> # define USE_SOCKTIMEOUT
> #else
> # define USE_POLL
> # if defined(vxWorks)
> # define FAKE_POLL
> # elif defined(_WIN32)
> # if defined(POLLIN)
> # define poll(fd,nfd,t) WSAPoll(fd,nfd,t)
> # else
> # define FAKE_POLL
> # endif
> # else
> # include <sys/poll.h>
> # endif
> #endif
> The intent was to use WSAPoll() only on versions of windows which provided it (and defined POLLIN). Could it be that XP defines POLLIN but doesn't provide WSAPoll()?
> What happens if you compile this with -UPOLLIN added to the CFLAGS? If that doesn't help, try adding a '#undef POLLIN' just before the block of conditionals. If t either of those fix the problem we'll have to figure out some other set of conditionals for Windows.
> On Nov 15, 2010, at 8:57 AM, Dirk Zimoch wrote:
>> Hi all,
>> I have a problem with the latest version of asyn driver on Windows XP. It tries to use a function WSAPoll() that does not exist in XP, only in Vista and newer. However I do not want use an old version of asyn driver without that function because of all the new features and bugfixes.
>> The code in question is:
>> #else
>> # define USE_POLL
>> # define FAKE_POLL
>> # else
>> # define FAKE_POLL
>> # endif
>> # else
>> # endif
>> #endif
>> It seems I have POLLIN defined but no WSAPoll.
>> I am using the compiler from Visual Studio 10.
>> Any idea?
>> Dirk
- asyn driver on Windows XP Dirk Zimoch
- Re: asyn driver on Windows XP Eric Norum
- Re: asyn driver on Windows XP Dirk Zimoch
RE: EPICS base on Windows with INSTALL_LOCATION on a different drive Mark Rivers
RE: the hex instruction convert Mark Rivers
<2010>
Stand-alone sequencer programs Ben Franksen
<2010>
