1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS base on Windows with INSTALL_LOCATION on a different drive
To: "Dirk Zimoch" <[email protected]>, <[email protected]>
Date: Tue, 16 Nov 2010 06:40:05 -0600
Using the current Cygwin make does not work, they dropped support for Windows type paths.  It actually works OK to build base on win32-x86, because base does not need configure/RELEASE files to build.  But when you try to build synApps, or perhaps when you try to install into another directory it won't work.
I use the current version of Cygwin, but I replace the "make.exe" program with one from an older version of Cygwin.  That works, although it's probably not the best solution.
Sent: Tue 11/16/2010 4:16 AM
To: [email protected]
Subject: Re: EPICS base on Windows with INSTALL_LOCATION on a different drive
With GNU make for windows
http://gnuwin32.sourceforge.net/packages/make.htm it works using paths
like C:/epics/base-3.14.12. It's only cygwin make that is not usable.
Dirk
Andrew Johnson wrote:
> Hi Dirk,
> On Monday 15 November 2010 04:00:07 Dirk Zimoch wrote:
>> I tried to follow the example in configure/os/CONFIG_SITE.win32-x86.Common:
>> INSTALL_LOCATION = C:/epics/base-3.14.12
>> This does not work because make reads lines starting with C: as rules
>> for building the file C. Using \\ instead of / also does not help.
>> So I tried
>> INSTALL_LOCATION = /cygdrive/c/epics/base-3.14.12
>> Now the microsoft compiler fails because it cannot read the cygdrive
>> path and thus cannot find the header directories. Here the problem is
>> that the PATH_FILTER only replaces / with \\ but not /cygcdrive/c with c:
> We don't support the use of Cygwin tools to build Base on the win32-x86,
> win32-x86-mingw and windows-x64 targets; you need versions of Make and Perl
> that understand the windows paths for those targets.  If you mix the two you
> just end up with the kinds of problems that you describe above, which neither
> Janet nor I have the time or inclination to try and fix right now.
> When building for the Windows API (using either the MSVC++ or MinGW compilers)
> I use the MinGW version of GNUMake and a Perl from ActiveState, although there
> may be alternatives to them.  When building for Cygwin I use the versions of
> Make and Perl that come with Cygwin.  Note that R3.14.12 will support building
> shared libraries on Cygwin 1.7 (using gcc-3, not gcc-4), although that still
> doesn't work on Cygwin 1.5.
> - Andrew
EPICS base on Windows with INSTALL_LOCATION on a different drive Dirk Zimoch
Re: EPICS base on Windows with INSTALL_LOCATION on a different drive Andrew Johnson
Re: EPICS base on Windows with INSTALL_LOCATION on a different drive Dirk Zimoch
Prev: Re: EPICS base on Windows with INSTALL_LOCATION on a different drive Dirk Zimoch
Next: RE: asyn driver on Windows XP Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: about the cPCI/EPICS system of APS/LBNL 王林
ANJ, 16 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
