1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: about the cPCI/EPICS system of APS/LBNL
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Mon, 15 Nov 2010 23:47:33 +0800
Hello,
I have some questions about the cPCI/EPICS system with motorola mcp750 of APS/LBNL.
In the paper "In-Situ Calibration: Migrating Control System IP Module Calibration from the Bench to the Storage Ring", it shows a cPCI/EPICS system as follows, and Labview communicates with the cpu board and uses ActiveX and SCA to interface to EPICS.
While from the paper "The Advanced Light Source Accelerator Control System At Ten Years From Commissioning" and Tech-Talk, I learn that the control system at the Advanced Light Source uses about 15 cPCI crates with mcp750 CPUs running EPICS on VxWorks, and 12 of them are used for fast orbit feedback system, which I concern with.
My question is that, What is the cPCI hardware infrastructure and the EPICS architecture of the system with mcp750 cpu board? How does EPICS on mcp750 control cPCI? Is the cPCI/EPICS system with mcp750 upgraded from the one above?
Thanks!
Lin Wang
Prev: EPICS base on Windows with INSTALL_LOCATION on a different drive Dirk Zimoch
Next: Re: Last chance to save the sequencer's pv layer Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS base on Windows with INSTALL_LOCATION on a different drive Mark Rivers
Next: asyn driver on Windows XP Dirk Zimoch
ANJ, 16 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
