1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MDrive - a novice in trouble
To: "James Rezende Piton" <[email protected]>, <[email protected]>
Date: Fri, 12 Nov 2010 17:31:43 -0600
I would enable all debugging on that serial line.  In your startup script, right after drvAsynSerialPortConfigure:
asynSetTraceIOMask("L0",0,2)
asynSetTraceMask("LO",0,255)
Then you will see all of the communication to the device.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of James Rezende Piton
Sent: Friday, November 12, 2010 1:15 PM
To: [email protected]
Subject: Re: MDrive - a novice in trouble
Hello, Mark
Thank you very much for the reply. I really appreciate your help.
As you told me, I moved back to the basic_asyn_motor.db and the proper C,S
values
for OUT. So the "syntax" error disappeared. dbDumpRecord shows now
the substitution for OUT:
grecord(motor,"IOC:m2") {
         field(DESC,"motor 2")
         field(DTYP,"MDrive")
         field(VELO,"1")
         field(OUT,"#C0 S1 @")
         field(HVEL,"0.1")
But I still have the same result:
     Illegal field value PV: IOC:m1 motor_init_record_com(): card does not
exist!
I checked:
epics> asynReport
L0 multiDevice:No canBlock:Yes autoConnect:Yes
Serial line /dev/ttyUSB0: Connected
L1 multiDevice:No canBlock:Yes autoConnect:Yes
Serial line /dev/ttyS0: Connected
I also dealt with Eos and asynOctetSetOutputEos and
asynOctetSetInputEos, just in case.
With asyn-4-13 testGpibSerial I can communicate and send commands
through the PV. For instance, I can get the parameter list produced
by the controller, showing it's ok.
As a novice, I played around a lot. I printed the variables card, brdcnt
and
brdptr->exists with that message about motor_init_record_com()
(in motorApp/MotorSrc/motordevCom.cc). I added a second serial port (and
its needed MDriveConfig) to see the corresponding change in the
number of boards:
exist! card =0 of 2 cards, existing= 0 (NO=0)
The problem is due to brdptr->exists, that is obviously false. But what
should I
do to have the "card" 0 available?
Have a nice weekend!
James
James Rezende Piton
grupo SOL
(Software de Operação das Linhas de Luz)
Laboratório Nacional de Luz Síncrotron - CNPEM/ABTLuS
+ 55(19) 3512 1228
BRAZIL
[email protected]
http://www.lnls.br
Just to recall:
==== my st.cmd:
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("MOTOR","/root/epics/synApps_5_5/support/motor-6-5")
dbLoadDatabase("/root/epics/synApps_5_5/support/motor-6-5/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
dbLoadTemplate("motor.substitutions")
dbLoadRecords("/root/epics/synApps_5_5/support/motor-6-5/db/motorUtil.db",
"P=IOC:")
drvAsynSerialPortConfigure("L0","/dev/ttyUSB0",0,0,0)
drvAsynSerialPortConfigure("L1","/dev/ttyS0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "N")
# IMS MDrive driver setup parameters:
#     (1) maximum number of controllers in system
#     (2) motor task polling rate (min=1Hz,max=60Hz)
MDriveSetup(2, 10)
# IMS MDrive driver configuration parameters:
#     (1) controller# being configured,
#     (2) ASYN port name
MDriveConfig(0, "L0")
MDriveConfig(1, "L1")
var drvMDrivedebug 4
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Sep  8 2010
asynOctetSetOutputEos("L0",-1,"\r\n")
asynOctetSetInputEos("L0",-1,"\n")
# motorUtil (allstop & alldone)
motorUtilInit("IOC:")
epics>
Em Thu, 11 Nov 2010 10:23:34 -0200, Mark Rivers <[email protected]>
escreveu:
> Hi James,
>> Can't set "IOC:m1.OUT" to "@asyn("L0",2)"
>> Error at or before ")" in file
>> "/root/epics/synApps_5_5/support/motor-6-5/db/basic_asyn_motor.db" line
>> 12
> I think you are mixing up 2 types of asyn drivers.
> The first is the asyn driver for the underlying serial port, which you
> configure with the drvAsynSerialPortConfigure command like you've done.
> The second is using asyn as the interface to the motor driver itself.
> Newer motor drivers are written using this interface, but older drivers
> like the drvMDrive.cc are not.  Thus, you should not have changed your
> motors.substitutions to use basic_asyn_motor.db, you must continue to
> use the C and S syntax, because the MDrive driver uses a VME_IO link
> specification.
> In your st.cmd file you will need the line:
> This tells the driver to communicate with the device using asyn port L0
>> Another question: why are there some examples with "grecord", instead
>> of "record"?
> That is historical from the days of a database configuration program
> called gdct.  "grecord" meant "graphical record".  It should be changed
> to "record" but it is not important.
> Mark
MDrive - a novice in trouble James Rezende Piton
RE: MDrive - a novice in trouble Mark Rivers
Re: MDrive - a novice in trouble James Rezende Piton
Prev: Re: Patch to subArray record Andrew Johnson
Next: RE: EPICS CA problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MDrive - a novice in trouble Ron Sluiter
Next: whether abvisable to use win32 to host EPICS development 王林
ANJ, 13 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
