1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: whether abvisable to use win32 to host EPICS development
To: 王林 <[email protected]>
Date: Thu, 11 Nov 2010 07:55:22 -0800
王林 wrote:
> Hello all,
> My task is to port a LLRF system to EPICS, I use vxWorks5.5.1 and
> EPICS-3.14.8.2, but the CPU board has not been finally determined,
> probably CPCI6200 or CPCI6190.
> A recommended CPU board is CPCI6200 with high performance and a
> MPC8572 dual core processor, which the crossgcc2.9.6 from SNS does not
> support. So I think I can use win32 as EPICS development environment,
> OPI and server(such as ftp and tftp), tornado2.2.1(supports MPC8572)
> on win32 as the cross compiler.
> But I am not sure whether it is an advisable choice, since I have no
> experience of developing EPICS application on win32, I don't know
> whether win32 is suitable as EPICS host, and what problem may occur
> frequently.
> I need advice.
> Thanks
> Lin Wang
WindRiver fully supports Windows as a development for vxWorks.
You should not have any problems there.
However, for EPICS I have always favored Unix for EPICS.
So, we use Linux as our development hosts and vxWorks 6.x.
Windriver fully supports vxWorks 6.x on Linux hosts.
Also, EPICS works great with vxWorks 6.x as well.
http://www.aps.anl.gov/epics/base/vxWorks6.php
If you need an NFS server to load EPICS applications to your target,
Linux is also great. :)
Cheers,
Ernest
whether abvisable to use win32 to host EPICS development 王林
Prev: RE: whether abvisable to use win32 to host EPICS development Mark Rivers
Next: Unexpected BURT incompatibility after Timing upgrade Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: whether abvisable to use win32 to host EPICS development Andrew Johnson
ANJ, 11 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
