1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MDrive - a novice in trouble
To: "James Rezende Piton" <[email protected]>, <[email protected]>
Date: Thu, 11 Nov 2010 06:23:34 -0600
Hi James,
> Can't set "IOC:m1.OUT" to "@asyn("L0",2)"
> Error at or before ")" in file
> "/root/epics/synApps_5_5/support/motor-6-5/db/basic_asyn_motor.db" line 12
I think you are mixing up 2 types of asyn drivers.
The first is the asyn driver for the underlying serial port, which you configure with the drvAsynSerialPortConfigure command like you've done.
The second is using asyn as the interface to the motor driver itself.  Newer motor drivers are written using this interface, but older drivers like the drvMDrive.cc are not.  Thus, you should not have changed your motors.substitutions to use basic_asyn_motor.db, you must continue to use the C and S syntax, because the MDrive driver uses a VME_IO link specification.
In your st.cmd file you will need the line:
MDriveConfig(0, "L0")
This tells the driver to communicate with the device using asyn port L0
> Another question: why are there some examples with "grecord", instead of "record"?
That is historical from the days of a database configuration program called gdct.  "grecord" meant "graphical record".  It should be changed to "record" but it is not important.
From: [email protected] on behalf of James Rezende Piton
Sent: Thu 11/11/2010 3:21 AM
To: [email protected]
Subject: MDrive - a novice in trouble
Hello,
I am trying to adapt the motorExApp,
under motor-6-5, to try a MDrive motor
under EPICS.
I (un)commented the proper lines (I think
so) and got the binaries.
I chose basic_asyn_motor.db as my base.
I changed a line in the original
motor.substitutions - instead of C and
S (card/slot), I created PORT and ADDR, following
the basic_asyn_motor model, with L0 and 2 (the axis address
recorded and tested in my motor controller).
======== motor.substitutions ==========
file "$(MOTOR)/db/basic_asyn_motor.db"
pattern
{P,     N,  M,        DTYP,     PORT, ADDR, DESC,          EGU,      DIR,
VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{IOC:,  1,  "m$(N)",  "MDrive", L0, 2, "motor $(N)",  degrees,  Pos,
1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
=======  basic_asyn_motor.db ========================
record(motor,"$(P)$(M)")
        field(DESC,"$(DESC)")
        field(DTYP,"$(DTYP)")
        field(DIR,"$(DIR)")
        field(VELO,"$(VELO)")
        field(VBAS,"$(VBAS)")
        field(ACCL,"$(ACCL)")
        field(BDST,"$(BDST)")
        field(BVEL,"$(BVEL)")
        field(BACC,"$(BACC)")
        field(OUT,"@asyn(\"$(PORT)\",$(ADDR))")
        field(MRES,"$(MRES)")
        field(PREC,"$(PREC)")
        field(EGU,"$(EGU)")
        field(DHLM,"$(DHLM)")
        field(DLLM,"$(DLLM)")
        field(INIT,"$(INIT)")
        field(TWV,"1")
My st.cmd.unix was correspondingly modified to
configure the USB-serial adapter and with
MDriveSetup(1, 10)
and
Then I start IOC
[iocWithAsyn]# ../../bin/linux-x86/WithAsyn st.cmd.unix
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocWithAsyn")
epicsEnvSet("TOP","/root/epics/synApps_5_5/support/motor-6-5")
epicsEnvSet("SUPPORT","/root/epics/synApps_5_5/support")
epicsEnvSet("ASYN","/root/epics/synApps_5_5/support/asyn-4-13")
epicsEnvSet("EPICS_BASE","/root/epics/synApps_5_5/support/../../base")
epicsEnvSet("IPAC","/root/epics/synApps_5_5/support/ipac-2-11")
epicsEnvSet("MOTOR","/root/epics/synApps_5_5/support/motor-6-5")
dbLoadDatabase("/root/epics/synApps_5_5/support/motor-6-5/dbd/WithAsyn.dbd")
WithAsyn_registerRecordDeviceDriver(pdbbase)
drvAsynSerialPortConfigure("L0","/dev/ttyUSB0",0,0,0)
asynSetOption("L0", -1, "baud", "9600")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "clocal", "Y")
asynSetOption("L0", -1, "crtscts", "N")
dbLoadTemplate("motor.substitutions")
dbLoadRecords("/root/epics/synApps_5_5/support/motor-6-5/db/motorUtil.db",
"P=IOC:")
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Sep  8 2010
Illegal field value PV: IOC:m1 motor_init_record_com(): card does not
exist!
# motorUtil (allstop & alldone)
motorUtilInit("IOC:")
epics>
I am not sure about the right asyn syntax, but
why that ``Can't set "IOC:m1.OUT" to "@asyn("L0", 2)"'' at all?
My USB adapter works and so does the motor communicate,
tested in the same SL system.
Thanks in advance for any tip!
James Rezende Piton
grupo SOL
(Software de Operação das Linhas de Luz)
Laboratório Nacional de Luz Síncrotron - CNPEM/ABTLuS
+ 55(19) 3512 1228
BRAZIL
[email protected]
http://www.lnls.br <http://www.lnls.br/>
Re: MDrive - a novice in trouble James Rezende Piton
Prev: MDrive - a novice in trouble James Rezende Piton
Next: whether abvisable to use win32 to host EPICS development 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: MDrive - a novice in trouble James Rezende Piton
ANJ, 12 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
