1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Suggestions and Priorities
Cc: [email protected]
Date: Wed, 10 Nov 2010 14:10:45 -1000
Andrew Johnson wrote:
Yes, if you want to influence the rank of a particular idea you do have to vote quite a lot for it to come up. Maybe that's not terribly efficient, but until someone else finds or develops a better tool this is what we have to work with right now.
As Lewis said, you have to keep voting if you want to vote for or against a particular idea. If you don't like the way that an idea is worded, rewrite it and submit your rewrite, if it's better it will get voted above the original.
http://www.allourideas.org/epics
the way this presents itself is a bit like "kitten war": http://kittenwar.com/ - which can be an enormous time sink if
you let it draw you into that, only, voting for EPICS ideas
is something that may or may not determine all of our future
work, and some directions we're all likely to take.
I voted some 180 or so times (it only counts the votes where one picks
one over another, not the "can't decide" ones) when it started feeling
a bit repetitive, but the results are kind of interesting.
Maren
EPICS Suggestions and Priorities Andrew Johnson
Re: EPICS Suggestions and Priorities Ben Franksen
Re: EPICS Suggestions and Priorities Andrew Johnson
Prev: Re: EPICS Suggestions and Priorities Andrew Johnson
Next: MDrive - a novice in trouble James Rezende Piton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS Suggestions and Priorities Andrew Johnson
ANJ, 17 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
